That’s how I always did it with mls gaskets, I then switched to stock gm gaskets and head studs and never had issues up to 25ish psiSilicone the water port holes and I like to drill the rivets out and coat everything in that copper spray, then restack for assembly.
Only reasoning for that is because what I was told many years ago. And it has never failed me.
Thats a good idea. I want to say high end lifters like Johnson have c-clips now that I think about it.Yes I have seen that before on V8 cars as well I replace them with c clips from McMaster I want to say it's a 14 mm diameter inside C clip
Absolutely not, I've been scouring the web for another w-body. i have a ton of stuff that will bolt right on another one!I hope this isn't your exit from 3800s! Sorry about your luck. That lady's insurance better pay up!
I'll definitely pull the truck carpet. You can have itid love to find a trunk carpet without a large trans fluid stain
jus sayin
The car is at a shop in Wood Dale, we can definitely cut the bitch up one day. The cupholder is still good!!! haha. Probably the main reason I bought the car back hahahademod party ill bring the battery sawzall
