Recommendations for Upgrades to 03 Cobra
JayzCobra
I am just got my 03 Cobra and I am looking for opinions as to the best bang for the buck for upgrades. It already has a UPR cold air intake and a magnaflow cat back..no chip or tuning...
Should i swap out the s-charger..? What do you think?
VenomInside
Just Grazing
SFO
What are your goals for the car.
I would do bf 2.76 upper w/ idlers and a tune.
joes03cobra10thann
I would say get a drag radial first, then maybe a midpipe, then pulley and tune. :biggthump
JayzCobra
03 cobra upgrade
I see a lot of Kenne Bell's put on, i want to increase hp/torque- but upgrade and not kill the life of the car either. I have done nitto's before - i thought i might do that again. Pulley and a tune were part of my thoughts as well
Wiked03
CSVT OG
Louisville, KY
2.76 upper
GOOD tune + mafia & bap
Drag radials
IRS brace
Good for mid to high 11s with practice.
Wiked03
CSVT OG
Louisville, KY
JayzCobra said:
What about a clutch... what are the weak links of the 03?
Weakest link is the halfshafts... use a good tire and if it wheel hops get out of the gas.
My stock clutch lasted 30k miles and over 120 passes at the strip.
gnxs
Corn-Fed Goodness
You'll need to define what your goals are for the car.
How fast/how much power do you want? What's your budget (if any)?
Blood on Blood
rumble baby rumble
Wiked03 said:
2.76 upper
Drag radials
IRS brace
Add in:
heat exchanger
level 5 half shafts
26 spline input shaft
no cat x pipe
catback exhaust
Dave
JayzCobra
03 cobra
Definitely maximizing the HP/Torque capability - beefing up the weak links to maximize the life of the entire car and keeping the stock look- all the while getting the best bang for the buck--- 11's would be nice - 10's i think i would have to change alot...
I also have nitorus system that was on an 04 cobra i bought and resold for anyone interested- it was never used- only the purge at shows..
Flatliner
I'm kind of a big deal...
I forgot to mention, many deals on these used in the classifieds here, SVTP, and/or modularfords and SVTUSA if Slash ever get's it romping ;)
IRS Brace
Drag Radial... MT if not daily driven in the rain
Clutch Quadrant and FW adjuster
MM Full length SFC
Practice launching it...
about $900 with install
Low to mid 12's good driving
Then when the clutch slips:
DFX and supporting parts
about $1200
consistent low to mid 12's
2.76 BF interchangeable pulley, in case you go ported blower, etc.
Idlers up to you, I have them, but Carl (WIKED03) doesn't... you may want them after you grenade one.
about $300, tune needed add $75-500
mid to high 11's
Add fuel mods:
KB BAP
60# Injectors
SCT2400 MAF
about $700, tune needed add $75-500
safer motor
Then your car should be prepped for:
Nitrous: $350-500. +tune
Whipple/ KB: $2500-3500, +tune
low to high 10's
gnxs
Corn-Fed Goodness
Since you mentioned "Bang For The Buck", here's my suggestion:
- Billetflow IRS Brace
- Quadrant & Firewall Adjuster
- Drag Radials
- Billetflow 2.76 Upper
- XCal2 with a custom tune by a GOOD tuner
You already have an Exhaust and Cold Air. You won't see much from an x-pipe or a heat exchanger and can add them later. The other stuff I would just upgrade as you see fit (e.g. the clutch when it goes, fuel system and MAF upgrades, etc.)
That's enough to net you 455-470 rwhp/~500 rwtq and high 11 second timeslips with a little practice. All for very little investment. Everything after what I mentioned will be "relatively" expensive for small gains.
My $0.02
Dragon03
Super hated on
+1 You should decide right now....I went thru 3 different pullies for the Eaton and then ended up sending my blower in for a porting and ended up going with a twin screw. I figure with the cost of the pullies and getting the port work done along with the tuning and dyno time I could have spent the extra $1000 and went with the twin screw first. But my car only stays fast for so long. I already have plans for the first part of next year :headbang: :rolleyes:
JayzCobra
you have a whipple- what reasons did you choose it, i see alot people with the kenne bell..
rdsnake
formerly RD SNAKE
Fuck it, go right for the twin screw, like I did :headbang:
Dragon03
Super hated on
Overall it was the price of it I picked it up for under $3000....KB will run you $3400+ on average (last time I checked). I also checked around and found that quite a few people had issues with the customer service people at KB. The KB and the Whipples are the same thing when I was looking into going with a twin screw I found that alot of the internal componets came from the same company...the only difference between the two is when you put your foot down the KB is going to scream like a mother versus the Whipple tends to be hell of alot quieter. I didnt see the need to spend the extra $$$ for the whine but thats just me ;)
JayzCobra
I originally looked at the KB and thought next about the whipple only because i noticed more KB's - but this is exactly the kind of inside info i was hoping to hear- it really helps you not spend money and regret it. I sincerely appreciate everyone's comments - especially with me being a newbie and all.
how about opinions on the diablo versus the xcalibrator?
