radio install help
Venomous01
So I just installed a double din in my 06 murano, everything works but the the speakers dont. But if I plug in the old radio then they work..... any ideas thanks
tinfoilhat
Riding the Hubble
You got the right plug adapter to go from stock to aftermarket wiring right?
1quick
coal city
sounds like there may be a factory amp and you got a connector that doesn't support that
Venomous01
I will check if there is a factor amp and get back to u guys, it's not muted that's for sure
If you have a factory amp you either have the wrong harness, or you need to connect the remote wire (blue or blue w/white stripe) if you have the correct harness.
SMRTSS1
Check for any settings on the headunit? Muted?
Been there, done that. Spent 3 hours trying to figure out what I did wrong until I checked the mute button. Almost broke my hand punching the wall over my own stupidity.
Venomous01
Possible might have the wrong connector than.... gf currently has the car so I will look into it tomorrow.... I'll have to the it apart maybe snap some picture and post it.... the radio and metra dash kit I bought barely came with any instructions... just how to install the dash kit and the radio only gives u a wiring diagram.
10thSVT_03
DRRRT PROSPECT
You probably don't have the harness that powers the factory amps
10thSVT_03
DRRRT PROSPECT
I think I have a few wiring harnesses from my old Titan. If they work for your application you can have them if they help.
10thSVT_03
DRRRT PROSPECT
I've got 3 different harnesses but no clue what numbers they are. I also have the interface for the Bluetooth and antenna adapter
10thSVT_03
DRRRT PROSPECT
Looking at the picture that's not one I have. I have the RCA's but only one harness
