Racing a 5000lb Barn Door
Spivitz
The Throttle is ur friend
40,261
46,244
37659
Hit the track yesterday, what i don't get is the thing always launches harder on the street. Seriously, not a chirp just punch the gas and gone.
First pass the dam thing ignited all four through second gear 40lb tire pressure
Second pass i dropped tire pressure to 25lbs.
Im tempted to get a drag set up, 17 in wheels and drag radials 20180330_121433.jpg20180330_131204.jpg20180330_103211.jpg
Spivitz
40,261
46,244
37659
Thanks Man, let's see
365 Forged rotation
Stock crank
Cam, ill post a pic of the card.
1 7/8 kooks
Off road y pipe
Magna flow
4000 stall
They cut and decked The heads bumping the compression a bit ( not all sure on that, im not a wrench)
LS7 Throttle body
Under drive pulley
E fans
Trans cooler
I threw out the air compressor and all the stock suspension
Intake
Running excellent with the Speed Inc tune
:wavey:
Spivitz
40,261
46,244
37659
This is weird, at least to me....
so at the track my truck spins all four, sometimes into second YET on the street, NOT a squeak. Seriously, just grabs & goes. My 60 on the street would be sick.......
& it seems I've launched harder @ Byron over GLD.
Full weight in either instance.
89,112
nah i get it.
maybe try drag radials all around at the track?
with how much rubber is on the track, your street tires aren't going to hold it...
my gtp everytime since it's been turbo, i'd get a 1.9-2.0 60', and then the car would obliterate the tires past the 60' and id be sitting there :dunno:
then the airport events... i barely had traction issues at all on my street tires.
Pressure Ratio
20,475
12,269
Glen Ellyn
Byron used a lot of glue when they prep. So not uncommon to see better 60' times there. Especially on radials.
Are you just rear wheel drive or still AWD?
If AWD I can see where the tires would be warm when on the street and cold at the track. Due to just sitting in the staging lanes, pulling up, and running. Air pressure can play a part as well. Less air pressure in a radial isn't always better. If too low the tire will distort and the contact patch changes. All of that could play into it.
