Quick Nitrous Question
Zack
4 Doors 4 Life
NW Indiana
Now that my Marauder is running right, time to hook up the gas.
Question is: Since just about everyone places the Nozzle before the Throttle body, is it ok to be after the TB?
There are many tapped holes in my crusher inlet I can place the nozzle, just making sure it is ok to do.
This is a wet kit FYI.
Thanks
qwik01cobra
built,novi2k,t56,solid
I wouldnt recommend it because you want the nozzle far enough away from the throttle body so that when it comes through it that it will get sucked/sprayed through the intake manifold equally. You dont want it spraying and leaning out one side of the motor ect...
Zack
Zack
4 Doors 4 Life
NW Indiana
I can see your point on a NA car, but remember, this is going through 2 humungous blower blades, an intercooler and a lower intake.
I do respect your point, and look forward to more responses.
Flatliner
I'm kind of a big deal...
Thanks
I've seen guys do it on KB's and Whipples on MF, so I don't see why not...:dunno: I agree with you that it's still being mixed in the TS as well. One advantage to having before the throttle body is that if for some reason the solenoid sticks, you can let off the gas and it should block any NOS from entering...
rocket5979
Gearhead
Round Lake, IL
Unfortunately even that is not really true because the IAC is there which will allow the nitrous through. Though it will not be as much as if directly sprayed through the TB. That is why if a person wants to be really safe in case of a solenoid sticking they can do dual solenoids on the nitrous side and still a single on the fuel side (if running wet).
IZZy
Powered by ES
you can put it on the inlet somewhere
Flatliner
good point ;)
