Quick lube vacuum oil extractor?
daturbosix
HNIC @ GoodFellas Garage
16,451
15,446
Jeff
and FYI
Gav'sPurpleZ
39,116
14,967
Pingree Grove IL
I don’t think I’ve changed my own oil since the last time I worked at one of those places, 2006? The trick has been finding a place that does a good job. I found one (Oil Depot Naperville, great guys, manager is always friendly and offered his pit for any work I wanted to do on the TA) but went against my better judgement this weekend.
Herbst High performance in Glendale heights....
If I had a lift, I'd be doing everything. The older I get, I have no desire to lay on my back in my garage and unscrew 25 bolts or push pins to get a stupid fucking plastic cover off just to get to oil pan. Figure if I go to the dealer, and they fuck something up it will be easier to get them to fix than someone like Jiffylube. I inspect my cars and walk the service manager around them before they touch them, then I inspect before leaving the lot including checking the oil.
i'm 38, i do not enjoy crawling around either but I dont trust many people with my stuff.
most annoying part of at home to me is disposing of the oil.
I bottle it in the "new" oil bottles and drop it at the local oil change place. they take the waste oil and filters ( as long as the oil is not mixed with coolant or trans fluid ).
DONE SKI
1quick
26,610
24,225
coal city
That’s what they use on boats since forever, I stripped the head off the drain plug on my wife’s car and just said fuck it I’m using the bucket pump though mine gets 95% of the oil out, here’s has the top canister filter and now I never have to pull it on ramps to change the oil sweet deal
Reactions: Gav'sPurpleZ
Thirdgen89GTA
19,398
16,019
Rockford
Bill
While the car is in warranty, I pay the dealer to change the oil, but I look over it with a FINE toothed comb. Better be the correct weight and quality on that receipt, and the level better check out when I go to look after I get the car back.
For cars not in warranty, I do the change myself.
Bru
10,220
Yeah I imagine on some cars it works great. Apparently not on an FB20 Subaru.
Bru
10,220
With as many stripped oil drain plugs and cracked oil pans that were on the hook for, I am not shocked at all.
Transmissions are already sealed and this is how you change the fluid. I would bet at some point the OE could head this direction as well with engines. If designed for extraction like this, I don't see a problem.
I also read that some VW oil pans are now plastic.
TommyGloves
5,868
496
CHICAGO
Tom Glover
I still try to change my own oil at home. I've installed Futmoto valves and it makes it super easy. Just drain right into an old oil container. If you have more than can fit, just flip the valve and switch containers.
http://fumotousa.com/
My Walmart by the house, I normally walk in by the Auto Center bays. They have a shopping cart where I can just go and drop off your used oil etc. The techs never ask any questions. I just walk in, drop it off, and leave. lol
Reactions: greasy
SleeperLS
14,386
8,261
West of the Mississippi
This story is the exact reason why I do as much as possible on our vehicles at home. I know it is done correctly and that make me feel good. I would rather the hassle of disposing of oil and other crap over dealing with a headache on a job done incorrectly.
I know it can be a pain and Inconvenient, but I have a very tough time trusting any place with my vehicles. I have dealt with enough incompetence at auto places to last a lifetime. The most frustrating part is that I am a nurse, and know how to do automotive maintenance better than most places...Disgusting
Pressure Ratio
20,510
12,413
Glen Ellyn
You use them too? I've been a long time customer and they are about one of two shops I trust with my stuff. They are always busy but turn out stuff pretty quickly and with quality work.
There are several manufactures that use composite oil pans. Not uncommon anymore. I'd probably trust those over steel sheet oil pans with a punched hole and threaded. Those and a JIffy Lube seem like a disaster waiting to happen. haha
Reactions: Aircal
Gav'sPurpleZ
39,116
14,967
Pingree Grove IL
frank frank
suggested them when the 1st transmission went missing at a shop that wont be named....
I contacted Eric regarding some work on my moms car. I was pleased with the experience and would go back again.
Reactions: frank
Pressure Ratio
20,510
12,413
Glen Ellyn
Definitely do. Their pricing is in line with other shops. The biggest thing I hear back from people I sent their way is that the felt like they could trust them to not over sell things.
They work on work trucks with a zillion miles to super cars. They have a big following of owners with high end cars. That says something too. It might say high end car owners are cheap and don't like the dealer. But I'm pretty sure it isn't the only reason. ?
frank
I have been sending customers to herbst’s before his shop was Even open and working out of his garage at home 20 years ago. I even have my own family going to him which at family parties they talk about his shop referring more people to him.
and what Pratt was saying, has a good high end car following, as well muscle cars and late models and everything in-between.
