Question on Vacuum/Boost Gauge
Grabber
Oh Hai
Wheeling, IL
Just installed my Boost gauge, and I am not sure how to accurately read it.
It's a mechanical Autometer Vacuum/Boost gauge reading up to 30 PSI and 30 In.HG.
When I start the car, it reads on about 15-20in.HG. I hit the gas, and it goes to 10 PSI, and no further. My stock boost gauge buries and goes about 3/4 of an inch past 10 PSI.
What is your opinion guys?
PS- Buying an Electrical Gauge is not an option at this point. Bad gauge, vacuum leak, etc?
Thanks!
-Chris
Zack
4 Doors 4 Life
NW Indiana
Could be a bad gauge, could be a bad bypass valve on the eaton (or mis-adjusted)
OR you could be making 10 psi!
blck10th
check and make sure that shitty line is not kinked anywhere
Grabber
Grabber
Oh Hai
Wheeling, IL
With my power level and the 2.76 PSI, I am pretty sure I am making more than 10 PSI.
The line was kinked, but I cut it and re-connected it. From what we can see, it is not kinked anywhere. I'll check the lines on the Eaton and the Bypass Valve.
blck10th
what should it be at boost wise? 2.76? lower?
Grabber
Grabber
Oh Hai
Wheeling, IL
Stock Lower. With the 2.76, I should be over 14PSI.
I've never heard of a Eaton Cobra with a Pulley swap, Stock Headers, Stock Lower Pulley making 462 RWHP and 486 RWTQ.
blck10th
i only made 457. that is with stage 4 port. i need a lower. I only made 13.28 psi on the dyno
BlaqSnake
PC Pimp
Aurora, IL
2.76, stock lower, CAI, High flow mid pipe, and catback
13.3 # boost (I think) and 467 HP / 476 TQ
blck10th
What size belt are you running. i think you can fit a 74" belt if you cut the tab on the tensioner. I was using the stock size belt. it slippy.
Grabber
Grabber
Oh Hai
Wheeling, IL
Running a 74.5 inch Belt. The belt that Billetflow suggests on their site for the 2.76 and 4 idlers.
Does it matter that my car peaks at about 6250? So, I am probably running 12-13 PSI?
10thSVT_03
DRRRT PROSPECT
I have the stage 4 port 2.76 upper 4lb lower and I made 210rwhp and 235rwtq @ 3lbs on 1 pull but was maxing out my stock injectors.. Once I get the 60lbrs we can turn it up again.. I think I am just at 190-200 now with it on a safe tune... I dont remember the belt size but it was slightly smaller than the Cobra Bob website recommended..
blck10th
I have the stage 4 port 2.76 upper 4lb lower and I made 510rwhp and 535rwtq @ 18lbs on 1 pull but was maxing out my stock injectors.. Once I get the 60lbrs we can turn it up again.. I think I am just at 490-500 now with it on a safe tune... I dont remember the belt size but it was slightly smaller than the Cobra Bob website recommended..
yeah i did not know i should get a lower when i did it:-o
10thSVT_03
DRRRT PROSPECT
have had the 60's and just got the carbon fiber cai from jlt
Yeah I wish would have bought them before my tune.. :( The JLT I bought from Kurgan when I got the tune.... I'm curious as to how my car will do when I get a new clutch also.. High revving its hard to get in gear....
