BUILD Quest for improved 4th gen Fbody drivability
3800 > ALL
TCG Blue
Jun 16, 2007
31,142
12,564
Laiiid back....with yer mind on yer money and your money under yer behind....
I love the corbeau in the tr.... It just takes a couple weeks of driving it before my ass cheeks mold to the seventeen inch width
At the dealership we used to clamp the headrest in the vise and bend the mount bars when customers requested changes.
It was a wrench with the twelve point teeth round out with a diagrinder that we used to gain leverage And not damage the chrome
Reactions: sktchy3.8
sktchy3.8
it'll work til it doesnt
TCG Blue
Jul 27, 2021
3,908
6,611
Honestly the firebird seats are where it's at unless you wanna spend the money for high end. A couple washers underneath on the front mounting studs to lean the bottom part back a touch is all they really need.
You ever sat in one of the leather Camaro seats? They're terrible.
sktchy3.8
TCG Blue
Jul 27, 2021
3,908
6,611
Yeah, need a seat to fit a wide body.
I have the leather seats in my Camaro. Par for the course I guess.
If you decide to change that I've got some brackets I'd get rid of real cheap. I had seats on backorder during the new age plague that never showed so I just ended up buying a parts car for the ones I wanted.
Bru
TCG Blue
9,236
$40 Goodwill amp arrived. Looks well-taken care of. Retails for $189 new, so 🤞
Bru
TCG Blue
9,236
I dove into the headlight replacement, first starting to diagnose why the driver’s side headlights weren’t getting power.
For the second time, the 5-pin headlight harness connector was corroded and gunky. I replaced this connector about 7 years ago, and it was serviceable this time, but that wasn’t my only problem. I hacked it together the last time, using poorly sized connectors and wrapping everything in copious amounts of electrical tape. A couple of connections were also corroded and falling out of the splice.
I haven’t soldered anything before, so thought this was a good opportunity to learn. What a pain in the ass when there’s no slack and very little run from the harness to the end (also my doing, hacking it off too short last time).
Anyway, everything worked after cleaning the connector and soldering the wires so I installed the new replacement LMC Truck headlights with 9006/9005 bulbs instead of sealed beams. Against the garage wall, the new housing (left) is much more focused than the original (right). This was with the engine off.
After I get these lights in I need to align all the new hardware and then take it for a drive. I also plan to explore LED headlights but have some concerns with depth and the retracting headlights.
sktchy3.8
TCG Blue
Jul 27, 2021
3,908
6,611
I looked into LEDs really hard when I was driving my bird and have a couple sets laying around I could send if you want to experiment. The biggest thing is gonna be getting them to fit in the housings without it being janky iirc. Of course it's next to impossible to find a size that will just pop in.
Bru
TCG Blue
9,236
Appreciate the offer. The GTR Lighting Ultra 2.0 appears compact and adjustable and is what I hope will work.
  • Love
Thirdgen89GTA
17,840
12,367
Buffalo Grove
View attachment 165410View attachment 165408View attachment 165409
Soldering is great, and your job is already done.
But after the squirrels chewed the harness on the GTA and I had to fix nearly 25 PCM wires in a parking lot, dragging the soldering station out there and trying to solder int he engine bay just sounded a pain.
So I picked up these, and I love them. Just need a heat gun and wire stripper. The heat gun melts the metal solder insert so it wicks into the wire, and weather seals the connection at the same time. Strip wires, slide the end on, twist them together, and heat gun. Boom done.
Bru
TCG Blue
9,236
Season 3 Wall GIF by The Simpsons
Thirdgen89GTA
17,840
12,367
Buffalo Grove
Well, I'm gonna bet that your soldered connections are better than these. But, for most connections I'd say they are good enough. I mean, if simply twisting the wires together is good enough, then this is 10x better. And your straight soldered connections are better still.
But the convenience is nice if its a pain to get a soldering iron into a tight spot.
Mr_Roboto
TCG Blue
Feb 4, 2012
22,873
24,523
Theoretically you're not supposed to use solder on car wiring because it can work harden and break off. Done it anyways admittedly, so take it for what it's worth.
That said, you really forgot the last step on the original repair. Those light blue connectors are heat shrink butt splice connectors. They're really nice and not cheap shit like the regular ones. If you had the wire stripped to a good length (not way over stripped like a few of those) and took the bic lighter to them after you probably wouldn't be touching it again.
Bru
TCG Blue
9,236
You can see the burn marks on the tubing. I tried :rofl:
TCG Blue
19,048
40
Well I don't have any immediate need for these, but they are now saved in my amazon shopping list. so that if/when the day comes, I don't need to try and find this thread again :ROFLMAO:
