BUILD Quest for improved 4th gen Fbody drivability
Bru
TCG Blue
9,238
Made some progress, but also hit a wall.
Mighty Mouse catch can is in. That was pretty straightforward. One hiccup/confusion over not-great instructions but customer service was top notch. It comes with an orifice PCV body but if your drivers side valve cover already has one, which mine did, then you don’t need to use it.
Then the chrs1313 ram air install with AC. What took the bulk of time was having to relocate the transmission cooler. Need a longer line but then will be good to go. And I finally got the ram air in its home but there are three body clips missing from my car that hold the front bumper cover up at the nose, and without them the nose droops, and blocks airflow. Hopefully I can still find these clips or a suitable replacement.
Bru
TCG Blue
9,238
So get this. I bought the AC version of the ram air because I still frequently use the AC. Today, I get under the car and the compressor is literally swimming in leaking dyed oil. I wish I would have checked earlier because I would have ripped everything out and done the big boy ram air.
  • Wow
Reactions: Yaj Yak
Bob Kazamakis
I’m the f-ing lizard king
TCG Blue
Oct 24, 2007
82,039
36,835
Ac ftw. Don’t hack it up, fix it.
SleeperLS
TCG Blue
Oct 19, 2008
13,988
7,322
39
West of the Mississippi
nice. Car should stay nice and consistent temp wise with all of the crap out of the condenser/radiator. Are these bottom feeders like the C5? It looks like you got it taken care of, but I bought these wands for the condenser/radiator to clean it out. One is water one is air. Got a ton out this spring with the air then followed it up with water. Worked amazing.
Bru
TCG Blue
9,238
Oh nice! Yeah, they're bottom feeders.
Reactions: SleeperLS
Thirdgen89GTA
17,840
12,367
Buffalo Grove
That is one of my regrets about the LT1 swap. The amount of fab work that needs to be done to put AC on a F-body LT1 setup is way too much. Have to cut/box the K-member, and its still so tight that one of the bolts on the back of the compressor bolts to the Motor mount clamshell. The other option is to convert to the Corvette LT1 setup, but that incurs a completely new accessory setup.
