GM Quest for improved 4th gen Fbody drivability
Thread
Sub and amp installed
Bru
I’ll eventually leave the house with the car and take more pics. Maybe now that it’s clean, it will stop leaking oil and the rear end will stop creaking.
Bru
Doing work with the Mother’s PowerBalls, Mother’s Mag & Aluminum polish, Adam’s tire shine. I stripped the wheels way back when, sanded them and then polished, but always forget how good it looks after fresh balls of power. I tried this spray-on clear one time but couldn’t get the hang of it, so just use a thick paint wax on the bare wheels. It likely burns off after a couple drives, but it helps for a little bit.
I think I need some balls for the lip on my GTO wheels. They're starting to look at bit tired now. Also I couldn't quite get my exhaust tips clean enough last time I washed them this last weekend. Think I let them go too long w/out cleaning them
Bru
I replaced the evap solenoid a couple years ago but it might be time to replace the canister. I still have some issues with gas coming out of the neck vent tube when full and driving spiritedly around corners, so that was one thing I wanted to do next. I thought that was my diagnosis when I poked around before, but I don’t recall.
Bru
2021 plans include 11.50s with the same baby cam (PB is 11.82) so here’s the start:
Chrs1313 ram air. It’s the AC version so I don’t expect the full gains of the non-AC version but it will help. The SLP lid never sealed that well so I’ll get er sealed up and slap this bad boy in.
Got a Mighty Mouse catch can on the way too. I noticed oil dripping out of my bandaged PCV system.
Then hero pass weight-reduction and a sticky tire to get into the 1.5s 60-foot (PB 1.61).
Unrelated, but I also want to even the ride height. There might be some sway bar preload happening but my ride height is a bit wonky (pass front is low while the rest are the same). Shocks could be installed weird too so will check that out.
Unladen:
Front driver: 26.5 — Front pass: 25 3/4
Rear driver: 26.5 — Rear pass: 26 3/4
Ram air, which will jut out below the air dam (the pictured top side will, the silver side is the air box side)
Gav'sPurpleZ
Pingree Grove IL
Resembles the Fast Toys ram air.
The Super sucker Ram air on Barney is ABS plastic and has a lower scoop section.
What tires are you thinking about ? 17" ?
Bru
I could be swayed one way or the other, but here are options I’m considering. Either will be mounted on a set of extra rims. Mickey ET Street R or Hoosier DR2.
C5 wagon wheel 17x8.5: My dad has a 99 C5 with the painted wagon wheels. He upgraded to chrome 2000 wheels and offered the 17s to me. The painted 17-inch wagon wheels are very lightweight. They’re a a half inch narrower, and aren’t polished, so they’re lighter than my 17s. 275/40/17 - A little wider than what came on them and probably what should be ran on an 8.5 inch rim. I see little potential for problems though.
16-inch stocker: 16x8. Narrower than the 17s but more sidewall. 255/50/16. Lighter still than my 17s and wagons. I might be leaning somewhat this way because I changed the shocks from Bilstiens to Konis since the last time. And while these are adjustable shocks, they’re only adjustable in rebound and not compression, so while I could get more travel out of the front by loosening them up there’s no adjustability in the back that would help. So I’m thinking the extra sidewall would give me a little more give.
That’s where I’m at.
Bru
Two updates: catch can arrived, Mighty Mouse Mild unit.
And I picked up my pop’s 17-inch wagon wheels for the rear to be mounted with a drag radial. I think I settled on the Hoosier DR2 because of availability, and lightness.
One wagon wheel weighed 19.5 pounds, which with a 22-pound Hoosier DR is 41.5 pounds. That’s down 11 pounds per wheel compared with the 01-02 WS6 wheels with Nitto 555R’s I previously ran.
Gav'sPurpleZ
Pingree Grove IL
A couple notes for the Can install:
1. the fittings only need to be "snug" not tightened with the hand of God ( add tape to a crescent wrench to prevent scratches )
2. My neighbor and I installed the can in the mount only to remove it in order to install the hose on the fittings. it was a bitch so having a 2nd person did help. There are no zip ties or clamps, this would be why the fitment is super tight.
3. Be sure to hear the click / snap when installing the breather/filter on the top.
(y)
