BUILD Queen: 4T80e Turbo 2001 Park Avenue
Ktj100
Posts
24
So this car has a ridiculous amount of work already put into it. Overtime I'll try to highlight some of the big points with the transmission swap and some of the other really cool details, but for now I'm going to briefly explain what the car looks like when I bought it and what's going on right now with the build.
I bought the car earlier this summer in very poor condition. All the high $$$ parts were already on the car, I've put less than $500 into it as of now. Bought the car for a great price, even if I had known everything wrong with it I still would have paid that much in a heartbeat.
The 4T80e conversion was incomplete (car wouldn't shift into 3rd gear), everything was leaking except the rear suspension air bags, lots of misfires, horrible squealing from the engine due to improper belt routing, and other things I'm probably not thinking of.
Here's what the car came with:
Engine:
-VS Cam with new GM timing chain
-Cobb Racing one-off turbo kit
-Camaro intake for beautiful routing of the charge pipe through the air/air intercooler
-(Unsure of what turbo is on it)
-No coolant overflow
-Stock Camaro TB and MAF (MAF was getting maxed out with the springs that came in the wastegate and blowoff)
-LS3 MAF installed but not wired up or tuned
Transmission:
-Stock rebuild 4T80e from a 2000
-3.11 gears
-700+ ft-lb rated LSD
-GM axles
-Cheap transmission cooler mounted in front of the driver's side wheel (effectiveness unknown)
Suspension:
-Stock parts, maybe some stock spec aftermarket stuff
-Broken away bar links in front (makes for an extra "exciting" ride when attempting to tame 400+ HP)
-Worn out 225 mm tires
Exterior:
-Rust
-Body panels in two different shades of green
-Rust
-Front end body panels are not from an Ultra (the car is an Ultra)
-Rust
Interior:
-Bone stock with a boost gauge and wideband.
-Lots of broken interior panels
-Heat and heated seats work :)
Fast forward to a week ago...
My friend Daniel has had possession of the car ever since we got it. He's been dailying while stress testing and taking care of little details, repairs, tuning tweaks, and some diagnostics. It's a win win for us because he doesn't need to spend money for his own car, he really enjoys the project, and I didn't have storage space or time for another project lol...
Anyways, even though we knew the mass airflow sensor was getting maxed out, we didn't really worry about it because we weren't getting any knock. During an extended 20 plus PSI pull he blew out one of the head gaskets. I'm sure the AFR was quite lean and I'm thankful we didn't lose a piston. We will be keeping a close eye on the afrs until we rework the mass air flow sensor system.
Before we can rework the mass air flow sensor, we need to finish getting the car running good. The afrs are all over the place at idle because the oxygen sensor hasn't really been working and the used one I had laying around that we tried to put in when doing the head gaskets also isn't working. While doing the head gaskets we found that the spark plug gaps were very inconsistent from 24 thou all the way up to close to 40. After finishing the head gaskets and regapping the plugs, the misfires are gone at idle and full throttle.
Next steps will be to convert the ignition system to LS coils and try another oxygen sensor. As soon as the AFRs are good and the misfires are completely gone at the same time, we will be putting a mini AFC on the stock Camaro mass air flow sensor currently being used.
TS
TS
Ktj100
Ktj100
Posts
24
That is fantastic! I would love to know how you get the 4t80 working
That's definitely going to be one of the first big things I talk about in this thread, but I'll give you the short answer now:
See that yellow wire in the top right of the engine bay going from the strut mount bolt to the PCM? That was the solution.
Judge none choose one
Posts
64,573
Needed a ground eh
10sec
Posts
25,127
This thread delivers goodness.
TS
TS
Ktj100
Ktj100
Posts
24
I suppose I should talk about the 4T80 sooner than later haha...
So the previous owner had actually done everything right in the swap. The only problem was that the 4T80 he used was too new!
The car/PCM is a 2001. The 4T80 is a 2000. Should work, right?
Nope. The '00+ 4T80 is electrically the same as the '03+ 4T65. If you try to swap a 2003 4T65 into a 2001, you'll find that the car won't shift into 3rd gear. That's what happened with this swap. 1st and 2nd were great, but no 3rd or 4th. He also found that he was even able to shift the car into 3rd and 4th using a Tech 2, but the trans wouldn't do it automatically.
From here out I'm going to refer to '03+ 4T65 and '00+ 4T80 as "newer trans" and the others as older.
I still to this day haven't found anyone else who was able to get one of the older PCMs to control a newer trans. This is the FIRST DOCUMENTED example of controlling a newer trans with an older PCM.
After I committed to buying the car, I asked the owner a lot of questions and did a ton of research, including talking to turboSBC400 at one of the Thursday night gatherings in Algonquin (or whatever his name is on here...). Hey keyed me off to the fact that the trans wasn't compatible due to the year combination.
I did a lot of research and looking at wiring diagrams and pinouts, and came up with a plan that I believed would allow the PCM to control the transmission. I have the information saved on my phone but I'm getting a "file too large" error... I'll finish this when I find a solution to that.
v6buicks
Posts
3,491
This is so exciting! It makes me want to build another car when I'm done with the Camaro.
TS
TS
Ktj100
Ktj100
Posts
24
I can't stay off the throttle now that all the misfires are gone... Almost ready to upgrade the MAF setup!
TS
TS
Ktj100
Ktj100
Posts
24
Back to the transmission control solution...
I found this table in the original 4T65e service manuals describing manual valve signals in different circumstances. It shows for D2, all four circuits are showing 12V, or OPEN circuits. For D4, two of the circuits were grounded:
I hypothesized that the transmission would work in D4 if I manually grounded two of the wires. However I suspected that car may also decide not to shift into reverse or work in D1, D2, or D3.
I ran the idea by Turbocharged400sbc Turbocharged400sbc and he told me it wouldn't work. He said the circuits need to be grounded within a split second of the shift or the transmission would go into limp mode.
But I'm stubborn lol....
When I took delivery of the car, I cut the two wires and grounded the PCM side to the strut tower bolt:
Took her out on a test drive and found all range positions working normally! Reverse, D1, D2, D3, and D4!
Since then, Daniel and I have been fine tuning the transmission settings and pressures, and have confirmed that no limp mode is activating. It could be that a limp mode would have activated without tuning out codes, but we tuned out all the transmission codes that were being thrown that were related to the "fix".
As of now, the only thing we aren't satisfied with is the torque converter. With pressure adjustments, it'll either lock up suddenly or slip continuously. I'm guessing the billet torque converter isn't made for soft applications :)
TS
TS
Ktj100
Ktj100
Posts
24
Back to the present: COIL PER PLUG CONVERSION
Been sick the last two days, so I hit the CAD hard with the coil mounts and ICM interface case. I made a separate thread https://www.thechicagogarage.com/threads/coil-per-plug-conversion-for-3800s.178670/ for a more detailed walkthrough of the coil per plug conversion, here's some of the more fun stuff that's specific to this car:
This sketch was the skeleton for both flex gaskets and the cover for making the ignition interface as weatherproof as possible in the engine bay. Both gaskets will be Flexible TPU and the cover will be PETg for now, possibly nylon later if I can get that printing good on my printer later. I should be fine with PETg though for this.
This is the gasket that molds to the top of the ICM, and fits into all the nooks and crannies around the outside. That bottom right spot may need a LIM gasket dab of RTV but the rest should be able to go on dry!
The indents around the bolt holes in the cover are specifically to allow reuse of stock ICM bolts. I want to avoid custom bolts as much as possible because I LOVE dropping them!
Front coil mount. This is a bottom view, you can see compression slots for lock nuts so I won't have to hold a nut AND bolt during install, or thread into plastic. The gray lines outline the removable piece that clamps the assembly to the oil filler neck outlet.
Mock up of front coil assembly with ICM interface.
Rear was a pain... There is extra junk on my rear valve cover (hence TWO circular holes), plus I only have an 8x10 print area.
$5.70 in plastic for this part... Probably cheaper because the slicer assumes use of Prusa branded filament.
daturbosix
HNIC @ GoodFellas Garage
Posts
15,156
Man, what happened to the days of tuning with fuel pressure! Lol
Ok, it's funny now, but it DID work.
TS
TS
Ktj100
Ktj100
Posts
24
Meant to include this: The sketch pattern feature stopped working on me so I gave up trying to keep it looking pretty lol... Hopefully it doesn't need much tweaking!
Posts
28,539
not having a bed bigger than 400x400 is what led us down the build a bigger printer rabbithole.... after buying the folgertech FT6 POS and deciding we could build a better printer blindfolded
