Pulleys
staceyyearsich
Crete
I need a whole need set except for the sc pulley and the drive train one.. or something. its by the water pump... where can I buy all of them?? I need to get all new ones the bearings in them are getting worn, I was curious if there was somewhere I can just buy the whole set and then I'll have a back up for the one I just replaced a month ago when it blew up!!!
staceyyearsich
Crete
Ment I need a WHOLE NEW set
Royalgtp
YOu need a snout? or a whole new SC?
ORa whole new drivetrain?
YOu may just need a new coupler in the snout....
staceyyearsich
Crete
Nooooo.. all the pulleys on the car that the assembly belt goes aroound etc...
alexgtp
Do you need the pullies for the Accessories or for the SC pullie assemblies.?
DO you need tensioner pullies also? Be specific!
gtphale
Stacy you really shouldn't have to change all your pullies. Maybe the tensioners. What is your car doing that you want to change them alll?
staceyyearsich
Crete
Well the ONE tensioner pulley fell off the car while I was driving the bearing was shot in it!! and u can hear the little pulleys making noise
staceyyearsich
Crete
so my dad said he wants to replace them all he took them all off and lubed them up, but the seal on them is getting dry rotted,
alexgtp
Going to have to take a look at it. Need to make sure which assebmly it is.
sweetness
you should be able to get all of the pullies through gm.. or gm performance parts direct... in fact go through GMPP they will get you a better deal.. GM will just take you in the butt.
BC
gtphale
Alex you find the one you were looking for??? Also Stacy if your going to replace then yea go to Napa or Murry's they are both really good at having stuff like that in stock. Not sure on part numbers though.
