Pulley Swap Pros
dole21
South Carolina
Ok...got a question.
Took off my dub system tonight and pressed on the zzp hub.
Question is
If I put a pulley on, it'll be flush with the hub, but the breather nut has to go over the outside of the pulley. IS this NORMAL?
I can't get the breather nut to even come close to fitting through the hole in the modular pulley, and i wasn't sure if its supposed to go on the outside. I think it'd be a pain to have to take that nut off everytime you wanted to switch pullies.
Anyone have any idea?
Thanks.
J.E.T.
I don't think the ZZP mps uses the stock breather nut. :unsure: I've had 3 (Gen1, Gen2, Gen2+machined snout) and never used the stock nut. The system comes with a black plastic cap to go over where the stock nut screwed in.
J.E.T.
toastyj
Hey JET, you're NOS bottle kinda looks like MODOK, man. Thats great!!!
alexgtp
Dole The ZZP system and the INtense use a push in plastic breather nut xhristmas style push in. you can not re-use the typical screw in one. Also the hub needs to be flush to the snout.
dole21
South Carolina
thanks guys, and miller when i called him last night.
gotta email and see if i can get that breather nut
alexgtp
go to the HELP center of any autostore. and but an x-mas plug.. thats all it is.. it will cost you 1.oo as opposed to intense or zzp charging you up the ass!!
