Pulley Puller Stud Size...
rjaz gtp
Naperville
What is the size of the stud that screws directly into the superchargers shaft for the pulley removal?
Unfortunately mine is bent and I need to get a few new ones, but I went to Menards and tried to match it up but couldnt find anything...the closest thing I could find was a three foot rod of 5/16, but that cant be the right size...
Any help would be appreciated!
I
imported_Ron Vogel
M8 I believe. I don't think you'll find them at your local hardware store. You can get them from McMaster, and they do will call. They're out of Elmhurst.
rjaz gtp
Naperville
Thanks Justin and Ron for the info....
I will check into McMaster Carr, and if I need one quick I will call you Justin.
Thanks
