🔧 BUILD PSJ's 1967 LS Turbo Camaro Build
Hi all, I bought this Pro Street 1967 Camaro. It had a 502 BBC crate engine and 8-71 supercharger. I have this driveline sold and it's getting pulled immediately.
LS + turbo is the plan. Maybe I'll keep it big tire and see who will want to grab a lane....
Current pic:
Reactions: Rico and sktchy
Pro Stock John
LS is the best engine
10,522
14,411
Chicago North Side
I'm waiting on some bolts from Unisteer for the heim bracket, it's threaded. Should have those tomorrow.
Starting July 3rd I'll start modifying it all to fit.
Step 1, cut the upper shaft down until the heim gets almost too close to the middle joint. I will leave good clearance. I'm not sure how much I can cut yet as the bar is bottomed out against the upper joint. The more I shorten that the more I think the angles will reduce even more.
That's the moment of truth I think, once I've cut at least once. If it's notchy I will roll up to Jimbo and try that joint (which I'd be happy to pay you for). I've never done something like this before so I'm working slowly. Of course Jimbo let me know your rate to come down here and finish it for me lol.
Reactions: Jimy Bilmo
Jimy Bilmo
CSVT OG Member
TCG Goldmember
60,785
I pay people to work on my junk, but I'm happy to let you see if you can make that joint work.
32,615
16,035
Maybe I'm wrong but I thought you're required to have a collapsible shaft.... that might be with a non OEM steering column now that I think about it.
Also I'm using that same style joint on one end of the 442 steering shaft and I was told the pinch bolts are good,and to use the bolt till you've got it good and ready to go, and then you need to weld it once you're sure you're good to go.
Same thing with the set screw units
Pro Stock John
10,522
14,411
Chicago North Side
Jimy Bilmo Dr. Jimbo so what I'm going to do at this point, is pick up the firewall / column bolts from D&R, put those in, and hopefully the notchiness does not increase hopefully gets a little better. I'm going to finish putting it all back together for now and then drive it. If it's acceptable, it all stays. If it's notchy bad driving, at least the car is easier to move, I'd maybe have someone step in.
In other news, still plan to lower the back of the car 1.5 inches. And just will go over some stuff to check it.
32,615
16,035
Before you go blaming the steering linkage I've had plenty of manual rack and pinions where you could feel the pinion mesh with each tooth as you turned it down the rack travel from end to end.
Unbolt the steering I'm joints and turn the rack itself and you might notice the same notchiness if it's the gear teeth
