project for sale
sallen85
Active member
project for sale or trade
1985 Mustang gt
This is a project, the complete interior is out of the car including the wire harness. The car is in pieces. I just have no desire to finish it.
The car has an 8 point cage with through the floor subframe connectors. The dash mounting tabs have been changed for the 87 up dash wich I have. As well as full black interior.
The car is an original 52000 mile car, the only rust is on the hatch and I have a rust free hatch to go with it. The doors have shaved handles, the engine compartment is smoothed annd painted gloss black three coats base and three coats of clear. Stock hood and Kaenan cobra R hood.
393 CHP stroker with main girdle and studs neutral balance
Brand new from ford 351 roller block
10.1 forged pistons
H beam rods
Comp cams 282 hr
Pioneer balancer
canton oil pan
comp dual roller timing chain
new ford roller lifters
Trick flow R heads (206cc)
Comp cams beehive springs
Comp hardened push rods
crane gold roller rockers
Lakewood scattershield
Tremec 3550 older TKO model
Spec stage 2 clutch
9” rear
AJE k-member and front coil over kit, adjustable struts
Hotchkis caster/camber plates
Steeda double adjustable uca
Pro 3i lca
50/50 lakewood rear shock with coil overs
upper and lower battle boxes
95 mustang front spindles
New power steering rack
Cobra anniversary front brake kit
1993 cobra master cylinder
New brake booster
Adjustable proportioning valve
Glenns performance sleeper tank
Enkei V1 wheels
Kooks stainless headers 1 7/8 with 3 1/2 collectors
3” stainless Kooks x-pipe
3” stainless bassani catback
Stock and aftermarket wire harnesses
painless efi harness
speedhut gauges
There is more, just looking to move on $5000 or trade for fuel efficient car, ford ranger, tig welder, atv, foid etc what do you have
intake and distributor are gone
EineKatze
No Stress
Joliet
I got a daewoo for ya. She sips gas... In all honesty though, nicely done engine compartment. GLWS...
S
sallen85
Active member
lowered price. would also consider a open car trailer and cash.
S
sallen85
Active member
Oops sure was, I didn't think I updated this site
