The 6.2L is like 430 ft/lbs, correct? So the extra torque should help. But hopefully, the torque curve of the 7.3L is fatter all the way through. We all know Peak numbers aren't everything. So hopefully the 7.3L drives better than the 6.2L due to the added torque and curve. And maybe in 5 years the stock rating will be closer to that 575 ft/lbs hinted at back in 2018?
I can't see Ford Performance or the aftermarket sitting on the sidelines with this motor. You know they are going to try and make this a performance engine. A SOHC with 445 cubes has everyone salivating to get their hands on one for development. Especially with engine swaps being easy due to available parts by Ford & the aftermarket. K-member, motor mounts, headers, and so on.
but ive said it once i'll say it again, who cares about "needing rpm" especially with these 10 speed transmissions nowadays.
my truck cruises at 1400 rpm at 80 mph and stays at 4k rpm and above if your foot is to the floor.
big ol meh.
Ford's not putting the 10spd behind the 6.2 for the foreseeable future so who knows if that woulda been the better option.
What would be the reason GM went with a 6.6 gas over using the current 6.2 found in half-tons then?
You mean not choked out? We want more RPM and powa!yeah all i can think and hope is that thing is choked out like 8.1 GM motors from the early 2000's
Seems the head flow good air. Will they at higher lift numbers than stock? How high of an RPM with the big 2.20" value offer? Will the big rotating assembly spin more RPM and not have brutal harmonics? And so many more questions. lol
I'm not sure what Ford guys are creaming their pants over the 7.3. From all I've seen, most Ford guys are just like you. A big old MEH...me included.ford guys: LS/LT MOTORS SUCK, PUSHRODS ARE FOR ANTIQUES AND ARE LAME AS FUCK.
also ford guys: I CANT WAIT TO SEE WHERE THE NEW 7.3 GOES
We ran the Ford F-250 and the Chevy Silverado 2500 on different days, but with an identical trailer set to slightly different loaded weights. The new F-250 returned a towing MPG result of 5.6 MPG with a moderate side wind (wind speed: about 17 mph). The unloaded result was 15.1 MPG.
When we ran the Silverado HD on the same loop at the same 70 MPH speed, we got 6.9 MPG and 16.0 MPG towing and unladed (respectively). The wind speed during the Silverado run was less (wind speed: under 10 mph).
that wind difference is entirely negligible imo.... 7 mph difference and a side wind, at freeway speeds? meh.
I look at it more for comparative purposes really, than real world numbers
but even still, each of those trucks might do totally different shit at sea level or close to it.
the ford might trump the gm near 800 ft elevation mpg wise...
True, but even still, when 5 Star dyno'd the 7.3 nearish sea level, the numbers still weren't really great...it made it's numbers only if you gave it a generous 20% drivetrain loss
I mean, manu's are making these things absolute dogs with torque management to the moon to prevent old men crying about "harsh" shifts. Take a look at Eagles 17 Cummins vs his 19 Cummins. The 17 was an absolute slushy dog with no power off idle. Ram fixed that in the 19 and now they have tons of power off idle.
I'm sure Ford is going to uncork these as more people get their hands on them and find that balance point between old man crying and power.
did they buy a tremor or a "normal" one.TFLTruck bought one , had it on the dyno with 5 Star, and has done a mileage loop. It has been extremely meh. Even the cat back system they put on it was meh
XLT, but their "plan" is to turn it into a Tremor
