Power bleeded for brakes
Status
Not open for further replies.
Aron
Anybody have one I can rent or borrow sometime soon?
I think I'm finally going to fix my car, and with the problems I am having with stripping the threads out of the bleeder holes, I don't want to have to open and close them. Power bleed them and be done with it.
Aron
Aron
Even with a power bleeder, don't you have to open the bleeder valves anyway? :dunno:
Yes but you just crack them and leave them open until you're done. Less chance of pulling the threads out when you only have to snug em down once.
01bluesnake
Cobra Brigade Mad Scientist
Once there loose, you shouldnt have to worry about pulling the threads as they require very little torque to close, i do have a air powered vacuum one if you need to use it, let me know.
:biggthump
Aron
Aron
:biggthump
Yeah, the caliper I need to replace this time was because we bled the brakes the old, pump em and crack the bleeder loose way. after doing it a couple times, the threads pulled out. We were working on the brakes to replace the other side caliper... which was leaking from the bleeder because the threads were stripped :rolleyes: Not taking any chances this time lol.
Thanks for the offer, but I don't even know where I'm going to do this yet, since I live in an apartment complex and can't work there. I likely won't have access to a compressor.
Aron
Aron
Yes and you always very too busy
deviantlx
i have an air powered bleeder but i always gravity bleed my brakes first. the air bleeder is nice for when i want all new fluid in the lines. mine is a snap on.
Aron
Aron
Well I think I'm going to try that one from Harbor. I appreciate the offers to borrow, but I'm so far away I may as well just spend the $25 and have one for next time. There's a Harbor right by where I work so it's convenient :)
Aron
Aron
Bought that one from Harbor Freight, and it worked awesome! Only took a couple minutes to bleed the brakes out. Best $25 I ever spent!
01bluesnake
Lol, glad it worked out for you and no broken bleeders. :biggthump
Status
