Powder coating kb plenum.
FuelSlut
FK RED STAR
Is it ok to powdercoat the plenum inlet on the kenne bell's? The reason I ask is I know powder coating is baked and I don't wanna damage something internaly on the blower in such high heat.
I wanna match the ugly cast look plenum black to the rest of the blower.
Zack
4 Doors 4 Life
NW Indiana
Take it off and give it to the powdercoater.
It will be just fine.
FuelSlut
FuelSlut
FK RED STAR
Can I remove the inlet without taking off the blower? If so that would be great than I don't have to worry about buying new gaskets they r quite pricey....
Zack
4 Doors 4 Life
NW Indiana
No need to remove the blower.. Inlet comes right off.
The factory SC gasket and intake gaskets are reuseable.
FuelSlut
FuelSlut
FK RED STAR
Ok nevermind blower has to come off.......that sucks..
FuelSlut
FuelSlut
FK RED STAR
I just looked at it you can't get to the bottom bolts without taking off the sc. Do you have a picture of the back of your 2.2 handy?
95SC
4 cams
MI
You can take off plenum from Eaton easy but good luck doing on a TS,even if you take it off you will have a crazy hard time to put it back on .
FuelSlut
FuelSlut
FK RED STAR
Why is it so hard to put back on?
FuelSlut
FuelSlut
FK RED STAR
Does this help - I used it when doing my EGR delete and re-routing the lines.
Yes it helps thanks. It just pretty much confirms that I have to pull the blower off. There is no room with it on the motor. I think I might just have the plenum painted black without taking it off the supercharger. I'll just have the blower part taped off.
