I wanted to do more with the existing server. It just can't do it. Not enough memory bandwidth or cores to handle hosting VMs. Specially not if I want to host things like an SCCM environment, or MBAM, while testing out OSD Deployments and all sorts of of other server things.This makes me want to do more with my unRAID server. I just use it for Plex and storage... Don't really know what else to do haha.
No RDP or anything like that.Thirdgen89GTA when you're talking about virtualizing your gaming rig, would you then run your monitor and keyboard directly to the server or would you use less powerful PC in-between and use RDP or something of the sort?
Making a mistake in diagnosing a problem, meaning you buy upgrade stuff when you don't need it is the best kind of reason to upgrade lol.I've been having this really weird issue of my computer not turning on when I press the power button. Or, it turns on for a split second and immediately turns back off. Almost like the PSU was discharging on boot attempt and inadvertently shutting the whole thing off. I was about ready to drive an hour to Micro Center and have them test the PSU and components. I have a Power PC and Cooling 750W that has gone through 4 iterations of builds and is still rock solid according to HWInfo (talking <1% fluctuations on any rail, 10 years and 4 builds later).
I built this Ryzen 5600X setup specifically because I thought my 4790k build was dead. Well, now I have the exact same issue I was experiencing except now with this 5600 build. I finally got it to a point it would turn on but it would sit at the Windows loading screen forever and just spin. I booted into BIOS and I noticed a drive missing, my "brand new" 860 Evo which is my gaming drive.
Turns out, the SATA data cable going to that drive was the cause of this whole fucking "no boot" issue. Including my 4790. I pulled the cable out of the drive and a bunch of gunk came out with it. Cleaned the drive-side of things as they looked fine, replaced EVERY SATA cable to all 3 of my drives, and the computer boots up before I barely even touch the power button now.
I was sitting here ready to drop another $200-250 on a new PSU and case (that Fractal Meshify C is calling me) all because of a cable I've used, for the same amount of time as my PSU, eventually started corroding.
I should go get my 4790k and see if that works. I bet a 3 dollar bill it's totally fine and will boot.
get starlinkOh lawd dats beefy.
My have to get my own local server setup, especially when this house goes through and my internet consists of 30Mb DSL.
I did have fairly nice ball bearing RL-26 rails for the case. But they be broke now.I have been impressed with the quality of the Rosewill rackmount cases for the price. I have a couple different models and both have been solid purchases.
Buy some rails and they slide nicely.
its amazing how expensive fucking server rails are. its nuts.I did have fairly nice ball bearing RL-26 rails for the case. But they be broke now.
I ordered a set of rails, but it cost me $70. Ouch.
They weren't even that high of a quality, just that they were made for the Norco 4224 chassis. However, Norco be out of business now and I can' find a set anywhere. I honestly never expected the rails of all things to fail.its amazing how expensive fucking server rails are. its nuts.
