It was too cheap to resist plus desktop needed an upgrade.RGB Puke!
J/K, its not RGB Puke, you need way more RGB's for that.
Yeah, I saw some info for the 3 series. I wouldnt mind the 3700 or 3800X for my unraid machine. The 6500 does what I need it to do, but I want to try to do some more VM stuff.
It really needs a video card or 2 actually. I apparently cant do much with an OSX VM with onboard intel graphics. Or Im just stupid and cant figure it out.
Even a 1050TI would do damage with plex transcoding.
Yeah. I'd take advantage of it. Except they haven't gotten it working in FreeBSD yet, so it also doesn't work in FreeNAS.
Would be nice to take advantage of some acceleration. But I figure with a Ryzen 3800x at the helm it will devour even 4k content.
Supposedly Plex fixed the 4K color space issue but none of the Plex updates fix the washed out colors when you transcode a 4K HDR stream.
Getting annoyed as other apps have fixed it.
Plex has been dropping the ball lately IMO.
Ever since they went to AWS hosted auth its been a downward spiral. Xbox One app has a memory leak or something and has been that way for over 12 months. Constant buffering even on direct play with wired connections. Pretty common issue and complaint across may Xbox one users. Constant UI changes are annoying as well.
Every update or feature add they seem to break something.
That is not too bad and within spec
All my drives are 65-80F. My external is 82F.
In a Lian Li full tower case. But it is also in the basement on concrete floor so it stays cool down there.
Noctua fans are supposed to be the shit. I’m no fan engineer, but with as dense as those drives sleds are I wonder if you’d be better with fans that are more static pressure than air airflow oriented. I just researched fans the other day and I think both the tan and grey Noctuas had pretty solid CFM and mmH2O ratings so that should help.
Probably not a bad idea. I might already have the ones you are thinking of.
https://www.amazon.com/gp/product/B07CG2PGY6/?tag=tcg21-20
They have high static pressure and has solid CFM.
Yep. I wish they would make black fans like everybody else.
