It's something you boot into and run that checks your memory for defects. If you're running shared GFX memory I'm just thinking it may be related to that. Hangs are weird animals.fuck is that
Could also be shittastic drivers. Maybe it updated?
Your superstition with this is exactly why I don't look at any new(er) trucks. I know the moment I go to see what else is out there, in the event I do have to replace the truck, that something really expensive on my truck will break. I haven't looked at trucks for myself since my warranty ran out in 2010.Ah, nice. yeah that was definitely another thought I had, since this does use an amd vega 8 chipset for onboard graphics, along with the GTX 1650 tandem. But yeah, I've double and triple checked that all the drivers are up to date
Still no issues tonight!!
I'm just waiting![]()
Doesn’t matter. It’s been RMA’d.Get a steel straight edge against it. Looks warped.
Maybe see if there is a way to flash something else to it?Got a couple Intel NUCs and an AIO celeron kiosk PC for free.
Also got a couple cicso Meraki switches but then found out they are subscription only which is fucking dumb. Good hardware becomes paperweight garbage.
Can't, chipset doesn't support openWRT.Maybe see if there is a way to flash something else to it?
Also can you make sense of this? Looks cool for cars but is it just basically an OBD2 scanner for Linux?
PyOBD Gets Python3 Upgrades
One of the best things about open source software is that, instead of being lost to the ravages of time like older proprietary software, anyone can dust off an old open source program and bring it …hackaday.com
Open source OBD scanner. Looks like someone spent the time to upgrade it and rewrite the code in python3.Maybe see if there is a way to flash something else to it?
As an owner of a Odyssey G9 49" that runs 5120x1440, I can tell you that comes already struggle to support 32:9 resolutions, and honestly, my 49" is plenty immersive, what I would love is if it were an OLED panel to get benefit from the unlimited contrast. The 49" OLED panel is the better offering.![]()
Samsung's 57-inch Odyssey Neo G9 DUHD Gaming Monitor U.S. Preorders Open
The 57-inch Odyssey Neo G9 has a 240Hz refresh rate and a 7680 x 2160 resolution.www.tomshardware.com
Ahh, metadata cleanup, I've been through it, its a pain.At work today figured out that the reason I couldn't connect to our DFS to manage it was that our AD replication was fucked up and we had some dead domain controllers in AD sites and computers. I probably need to finish purging that, but I ended up shooting a domain controller that was acting like it got hit in the head. I'm not sure if DFS will stabilize out afterwards or if it's still massively fucked though. I am going to end up having to go through, reverse engineer the namespaces, move shit around and go from there.
So, got the reason for the failure. The coolant had a bunch of internal corrosion/gunk which reduced flow through the cold plate or radiator.Welp, NZXT is replacing my Kraken X53 AIO with a new Kraken-240 AIO, still trying to find out what failed on the old one. Personally, based off the pictures of the cold plate, I'm wondering if it somehow warped based on the CPU outline in the copper.
Called it.So, got the reason for the failure. The coolant had a bunch of internal corrosion/gunk which reduced flow through the cold plate or radiator.
Which is annoying as its a fully sealed system that its not even 3 years old.
