I don’t expect this to be super entertaining for most, but I’m bored and I think some will like this.
So, those that frequent my ongoing vehicle thread know about this truck. I’ve owned it just about a year. Purchased it from a Ritchie Bros auction for $1,100 with 281,000 miles. Ended up finding some paperwork in it, figured out the company that owned it and by chance had a friend that is a foreman over there. Found out it was originally the owner of the companies truck, purchased new in ‘05. He put most of the miles on it from ‘05-‘15 when he got a new one, and it was given to the office staff for running to go get permits filed with the city, DMV, coffee runs, etc.
When I got it it ran/drove. Had a CEL, flat tire, wheel bearing noise and was dusty as hell from sitting in the auction yard.
It had 281,000 miles on it when I got it, currently just shy of 306,000. I did a fair amount of work to it right when I got it.
Truck- $1,100
RockAuto generic wheel bearing- $56 x2
Plugs/wires- $38
Upstream o2’s (CEL)- $110
Front pads, rear pads/rotors, new caliper bracket, caliper pins and boots- $166
Front window tint- $100
Everything except the wheel bearings and plug wires was AC Delco.
$1,626 invested so far.
Then I decided to put a plow setup on it. Already owned the Western plow, wiring harnesses and controller. Got a used set of truck side mounts for $200 and a conversion bracket from the newer mounts to older plow for $150.
Plowed all last winter without a hiccup, all word of mouth and FB posts. Made like $6,400 lmao.
Only other thing I’ve done to it recently was the braided brake line off the master that decided to blow, that was $33 on Amazon next day for an OE line.
So I have $2,009 dollars into this truck. It runs great, makes great oil pressure and does 85 down the highway without a shake, shimmy or pull. My only gripe (moreso my GF and parents) is that it’s starting to look kinda ratty. The hood, rockers and drivers side wheel arch are starting to rust.
The plan is to track down some Tahoe fender flares, a new hood in the same color (maybe HD hood??) and cut out the rockers, treat them with POR, cavity wax the dried POR and put plastic covers over them. Maybe track down some NBS 20’s for the summer? It’s going to need manifolds done next spring. Just had an adjacent bolt brake next to an already broken one, so it sounds a little scrap truck like when it’s cold. Shuts up after 45-60 seconds.
Thanks for coming to my Ted Talk. What would y’all do with it? I plan on running it and working the shit out of it as long as possible for as cheap as possible. Think of it as a budget GMT-800 torture test.
Truck- $1,100
Plugs/wires- $38
