I was actually wondering about if Tesla’s and other 100 percent electric cars get reduced range when it’s this cold.
I would have imagined there is some sort of battery heater or something to prevent that. IDK.
On a couple of our newer trucks with the California clean idle BS, I set the idle at 1,000-1,500 with the cruise control. And it’ll run all day.
Even our older trucks I will still set the idle with the cruise just to keep the engine temp up.
But these are all Peterbuilts, Kenworth and a Freightliner. Not pick ups.
But the one F550 with the clean idle BS, I/we wedge a wood lathe on the gas pedal and seat to keep the idle up at about 1,000 and heat on all day. I like my shit warm. Never been an issue.
It won’t fire as in your 6.0 or my Cummins???
[MENTION=7923]DEEZUZ[/MENTION] does cycling the glow plugs multiple times help? I didn't plug mine in this morning and it cranked/barely popped over for 30seconds so then I stopped cranking and cycled the key 3 times in a row and it fired up. Seemed like it helped.
This will be me tomorrowLets see some cold start videos from the gasers tonight or tomorrow morning
https://www.facebook.com/LsxSquarebody/videos/860448184288571/
So what’s my next step? Wait till temps are closer to 0? I made an appt to drop off at dealer but what does the dealer do? Change filters and then what?
https://www.thechicagogarage.com/forum/showthread.php?t=162588What kind of electric range do you get when its this cold? I would assume between the battery heater and interior heat next to none
