Anyone have a recommendation on a plumber in the western burbs (I’m in Carol Stream)? Need two silcocks (outdoor faucets) replaced. Problem is I’m on a slab so the connections are behind drywall.
Might need the main shut-offs replaced as well.
Front silcock leaking from valve gasket up through anti-siphon. Rear leaking from somewhere in valve, but can’t get screw out of the handle to remove to remove the handle, to get the compression nut off. I was able to back the nut off and put in new Teflon cord, but it’s just leaking worse.
