🔧 BUILD PJ’s bad idea - notch edition
Figured I might as will document this train wreck. I bought this car a long time ago as an unfinished project and parted it out. Sold the caged shell to a buddy who needed a replacement. He ended up getting out of racing and it sat for a few years. Well he made me an offer I couldn’t refuse… so it’s back
Intentions are to fix some things I don’t like, finish some things and make it a nice complete roller. At that point I will see if I can sell it quick for a little profit, otherwise I have an LS and th400 to put in it for the spring
Some details:
- Certified 25.3 chromoly cage (good for 6.50 in the 1/4 at 3600#)
- fiberglass front clip, doors, trunk
- TeamZ front suspension
- Strange brakes
PJx5x
1,481
1,877
Villa Park
Been swamped at work. Forgot about this car and thread
Oh come on dude just Weld a machine screw head end to the bearing ID and put it in the end of your slide hammer and thread a nut onto the threads pull the f****** out and toss them in the garbage
Good call. I ended up putting a solid rod thru the bore, tacking it to the inner race and giving it a whack. Took 30 seconds
PJx5x
1,481
1,877
Villa Park
Throttle body done. Pretty straight forward now that I’ve done it. Would contemplate modding these as a side hustle but would have to sell them at $200+ ish and I don’t think sloppy people like to spend that much lol
Billet Australia chyna fuel pump hat is here with triple 525s (1 backup)
Messing around with potential alternator and turbo mounts. Intercooler has spiraled and putting turbo to the side might be best option. I don’t want to use a scavenge pump so I’m a little worried about turbo being high enough. Luckily I have the motor pretty low
Aforementioned intercooler core thanks to Mike K2K. Treadstone big boi 6” thic. Need to make a mount to that lower bar so I can make cardboard end tanks
Laser cut coil mounts I designed to fit how I wanted and test fitting chyna injector spacers for the 210s. Will replace orings with ones I trust from McMunster
Did some ghetto bench top testing with the MaxxECU and got the Silverado PWM fans to work. They don’t fit the Champion radiator too well, so custom shroud mount is in the works
3D printed some custom tube clamp things with an adjustable strap to move and angle the steering column where I want it while I make a real mount
Good lord… Typing out all these half finished projects made me realize I really need to see a doctor about having ADD
PJx5x
1,481
1,877
Villa Park
After dicking around with making an alternator mount to work with the motor plate I finally took a gamble on an ICT setup (thanks Amazon free returns).
Ends up fitting perfect, and the back plate tucks between the motor plate and cylinder head. Has an oem style tensioner too. I could definitely copy this design with laser cut alum for cheaper but I don’t think it’s worth the hassle
Designed a throttle cable bracket for the Motion cable Boostie Boostie got me for my birthday. Used a tab and slot design out of 1/4” aluminum that I’ll weld together. 3d printed one works perfect and is strong enough, so I don’t see the aluminum having any problems lol.
Fit some 0.040” aluminum sheets for the floors. These still need to be bead rolled and drilled for rivets
But it allowed me to take some measurements and sketch up a fuel cell. Flat shelf on the bottom is for the in tank pumps to pull from
Almost 20 gallons… little crazy lol. I need it to be that deep for the pumps and that wide to mount between the rails. So I might just take more off the front nose
Last but not least, I got my headlights and taillights from Terminator-Fux Terminator-Fox installed
PJx5x
1,481
1,877
Villa Park
My laser cut junk came in so I assembled the throttle bracket and welded the back/bottom
Made the intercooler mounts- like trick chassis tabs. Printed the drawing to scale to transfer the bend lines. Then welded a receiver cup on for the threaded aluminum bushing. Makes it so you drop the intercooler into the cups and install bolts easily
Mocked the intercooler core up and tacked the aluminum bungs in place. Welding thick aluminum at 250 amps upside down sucks.
Will add an upper mount after the end tanks and tubing are done
Also thanks to Boostie Boostie for tricking me into buying an LC9 6 months too late
