I would definitely prefer Byron. I'll bring my car.
I'll hold the rear fender while he's doing a burnout and push the bumper mounted data logger button.If you keep it I can check tire pressure at the track and act hard on the line at GLD. I'm not buying white Oakleys or wearing a flat brim hat though.
you're kinda a geniusFinished welding in that bar. Finally got to use a bendy tungsten fromBeerOrGasoline to get in the corner
Then my order from SendCutSend came in (Easy only laser cutting). First thing is the trunk dzus rails. I stole the idea from Racecraft and tweaked some things and drew it up
I wanted the rivets for the springs to be recessed like on a normal dzus tab (shown below). So I made a die set, and hardened it with a torch and cup of water lol. Uses a pin to center both halves over the hole. Squeeze in vise. Worked pretty well for a hack
Yea and the quotes are generated instantly. Can switch between materials/thickness. Shipping is included in price tooSo do they just require a dxf file?
Cause that’s no where near as fun and I wanted to see if I could recreate the other stylewhy not just countersink the rivet holes and use a countersink rivet
You can show your support by trading boogered taillights for a fresh delivered hot n ready eachHave I mentioned yet that I like your bad ideas?
welding on the trunk ruined the paint, you'll never sell this pile of junk now.
3D printed a couple jigs and embedded magnets in them. The step is the same thickness as the fiberglass trunk lid so the rail is held at the right height to tack in place. Did that and then stitch welded them in
I have some dzus transfer punches I put in the rails. Laid the trunk on top, got it centered and tapped it down. It marked the hole locations on the bottom to drill out for the fasteners
I installed the 17” strutless wing from Robert Carter. Pretty impressed with the quality from a guy making them by hand. I ran out of clecos doing it. Not looking forward to installing all the tiny screws when the time comes
Do you know what a reasonable price is these days?Will keep an eye out. The deals are out of state, I got my LC9 from a guy in IN.
