Picked Up A New Air Compressor
SleeperLS
Desert Racer
Sandia Mountain
I have been wanting a smaller air compressor for the garage that would work for tire inflation duty, and blowing stuff off/out. I don't have the need for a large compressor at this time, but still wanted something quality that will last. I was wanting something with a lower noise level but the more silent units in my price range seemed to have QC issues.
I present the Makita mac700 big bore 2.0hp 2.6 gallon oiled compressor. I got a 50' Goodyear hose to go with it. The fittings I have aren't the best and leak at the male/female connections at times, so I will have to find a better quality fitting at some point.
Overall I am very pleased with this unit. Works great for tire inflation and seems to be quality and solid. Noise level isn't really that bad, so that is a plus. So far I would highly recommend this product to anyone that is looking for something similar. On to the pictures.
greasy
LTTR BOX
The Litter Box
Get the Milton couplers off of Amazon. High quality and no leaks. I love all of my Milton stuff.
Spivitz
The Throttle is ur friend
I had one for years, good little compressor. Nice pickup
Intel
Palatine
x2 on the milton conenctors. Probably leaking because you are mixing and matching different type of connectors as there are at least 3 different types.
Looks nice for a small unit.
SleeperLS
SleeperLS
Desert Racer
Sandia Mountain
I bought a set of industrial connectors, not sure what brand but they are all the same brand. I think I just got junk.
cdh027
Sweet compressor. What's even sweeter is where you live. I see green grass and trees.
SleeperLS
SleeperLS
Desert Racer
Sandia Mountain
I knew very little about New Mexico until I visited here a few times and finally moved out here. The more mountainous areas of the state are a hidden gem. Tough to find weather any better and we still get all the seasons.
SleeperLS
SleeperLS
Desert Racer
Sandia Mountain
I ordered a new set of Milton compressor fittings for this bad boy. Should be here this week.
SleeperLS
SleeperLS
Desert Racer
Sandia Mountain
[MENTION=60]greasy[/MENTION] good shit man. I switched out all the couplers with Milton stuff and everything works flawless with zero leaks.
I use this compressor quite a bit around the garage and it does everything I need it to. I mounted a couple of new tires on my x3's beadlock wheels and the compressor had no issue keeping up with the demands.
greasy
LTTR BOX
The Litter Box
I told you! I would not steer you wrong, glad it worked out man.
Escrow shortage crew
I figured this thread was fucking gay for a reason.
Fuck you john
Very handy, Andy
mrgreystone
New member
Hi all, new to the forum. I'm looking for for a new air compressor, mainly to power impact wrenches and ratches. But it has to run off of 110 volts because I don't have 220 in the garage and my breaker box in the house is all tapped out. Yes, I realize I could spend more money and find a way to get 220 to the garage. But that's not going to happen.
I've explored the SCFM ranges of all the compressors in the 20 to 30 gallon range (Dewalt, Porter Cable, etc), and many have great ratings and are advertised as being able to run an impact. But I'm worried that rating is only for lug nuts and other easy stuff. I'd like something that will buzz off an axle nut or even a crack pulley if necessary.
Another limitation is price. I'd love to spend no more than $600, so try to keep that in mind when making suggestions.
Funny. This thread wasn't even really about the air compressor
