NEW RIDE PANDA's - Ballin on a budget gas saver BMW.
Commander
Posts
109,941
Believe it or not I'm having a hard time finding snow tires in that size... I might have to buy 17's to find tires. :rofl:
Id probably go with OEM BMW E60 wheels from that period. Been looking FB and craigslist.
run 205/60/r16.
exact same height as 225/55r16 (which should be on there i'd guess?)
just slightly narrower.
tons of options in that size for winter tires.
PANDA
PANDA
Posts
36,284
Wisconsin Northwoods
run 205/60/r16.
Good idea. I can buy the tire I wanted in that size.
Bridgestone Blizzak WS90 | 205/60R16 (tirerack.com)
Looks like .8" narrower. Not sure I like that but should move through snow easier.
Bob Hope
Formerly Alive
Posts
76,865
Really it’s just the style of wheel, I’m sure there’s plenty of oem wheels that would bring it up a notch.
What about a narrower tire? 16” general arctic altimax tires were so cheap in 16
Ron Vogel
Posts
4,681
As long as the offset is right, you can do 3 series rims too. Shouldn’t be too bad of you go to 17”s since there more choices than x drive models
PANDA
PANDA
Posts
36,284
Probably should have done a little research and replaced this myself as it does not sound very hard but dropped off the 525i at the mechanic for a PO444 SES light. Purge valve circuit open.
Labor: $135
Part: $114 (BMW OEM)
They also hit me for a $99 diagnostic fee. Is that standard? I am trying a new shop that my girlfriend uses because they offer a 3 year, 36,000 mile warranty and complete repairs very quickly. I looked at a few repair invoices from my Tahoe that are a bit more straight forward from other shops and I don't see a diagnostic fee.
b00sted
Posts
5,267
I had the identical car, but it was auto. It ended up developing a bad misfire at idle and I couldn't track down the issue. All of the BMW forums/etc more or less suggested just throwing parts at it until it was fixed, so I sold it instead.
I have the blue BMW-specific diagnostics cable if you want it. It's the blue K-line cable shown here: https://bcables.com/
PANDA
PANDA
Posts
36,284
Thanks
I picked this up a few days after buying the car. Figured I would need it. :rofl:
AmazonSmile: FOXWELL NT510 Elite Full Systems Scanner for BMW Automotive Obd2 Code Reader Bidirectional Diagnostic Scan Tool with SRS EPB SAS TPS Active Test Oil Reset Battery Registration : Automotive
Gav'sPurpleZ
Posts
36,113
Pingree Grove IL
When I worked at a dealer many moons ago ( and for that matter the dealers that I have dealt with recently ), the inspection fee is the minimum cost.
Once the vehicle is diagnosed, the inspection fee 'should go toward the repair'
It's essentially a 1 hour charge, so if the repair is 1.5 hours of book time, it should be the labor rate x 1.5 hours + the part.
Not a separate line item.
Sounds like BS if you ask me. I don't think you need any of us to tell you this but just ask the next repair facility how the inspection fee works when approving work.
:bigthumb:
b00sted
Posts
5,267
IT'S BRETT BUBBLE TIME
Posts
63,223
Labor: $135
If we have to pop the hood or hook up scanner, then yes you're getting charged our $165 fee.
If you drop off truck and part and say change this, you have to sign a waiver saying we Completes no dio and are not responsible for result. That's even if we accept the job. 9/10 if you bring your own parts we won't even take the job.
You don't take a steak to the steak house and have them cook it for you, do you?
blueoval4life
Posts
3,572
Wheaton, Illinois
Where does it say he brought the part in? Also, I have always had the diagnostic fee waved if the service is performed by that particular dealer/mechanic.
Posts
63,223
I never said he brought his own part in, just stating what we do.
Maybe the Tahoe work orders were different cause parts were supplied/no dio?
Posts
63,223
I don't understand the waiving of the dio if you're doing the repair. I'd never wave the dio fee. Ever. Come pick your vehicle up and spend another day dropping it off at another shop, organizing another ride/missing time at work. 🤣
You're paying for our time to find out the issue. Now whether it takes 5 mins or 1.5 hours, what's that matter?
Somebody has to pay for my time and materials and tools used to dio.
Gav'sPurpleZ
Posts
36,113
Pingree Grove IL
You deal with more fleet vehicles and HD work trucks.
I think the mindset of a typical passenger car dealer is there has to be some incentive to 'appear to be given to the customer' for them to approve you to do the work.
The last year I was at the dealer, 2005, the labor rate was already $149.95 ( Chicago).
If a soccer mom brought in her 100k mile Plymouth voyager and had a check engine light. She signed for the 149.95 diagnostic fee.
If the tech ran the code and confirmed it was a tps sensor and the labor to change it was 1hr.
Then the cost is the 149.95 plus the part.
Some techs would write it up for 1.5hrs and some service writers would bump up the labor because it helped their numbers.
We all know it will take the tech 10 mins to change it.
Just explaining how things were handled there.
Rico
Posts
96
Looks clean! congrats! Highly recommend German Auto werks in Lake in the Hills if you ever need service or a 2nd opinion on something. They only work on Bimmers and Mini's, very knowledgeable, professional, and competitively priced labor rates.
