Painting parts underneath the hood??
98 TGP TOY
Morton, IL
So my brother mentioned that he wanted to paint some parts underneath the hood. His car's engine bay is in perfect condition. There isnt a drop of oil anywhere, nothing, spotless. So I want this paint job to be done properly and to hold up. So I was wondering what is the best way to paint the metal and plastic parts underneath the hood? Also, many people stress that the spray clear coat is not good. How much would it cost to take the parts to a shop and have them clear coat it? Any and all advice is welcomed. Thanx guys.
BigJermGTP
Montgomery
You definatly want to take the parts out of your car first that you want to paint. You should stick to high temperature paint, out of a can is all i know of. I work at a body shop and the clearcoat we spray for the outside of a car is not for high temperatures,like next to an engine. It will look good for a few months and then it will start cracking and peeling because of all the stress. I know theres not too many colors to pick from in the high temp. paint but if you want it to last and not have to re-do it a bunch of times, i'd stick with that. Preping the parts for paint should be detailed on the paint your using, just a word of advice, read the directions if you've never done it.
syP
Not Banned
Downers Grove, Illinois
hahaha just paintin the shit myself...
spray Simple Green and wash off/ dry off several times unles clean (even tho it is)
High temp primer if you want
High temp paint
High temp Clear coat....
you will achieve this if so..
GTPPWR
Rockford, IL
when I painted my intake on my white gp. It was still on the car. I cleaned it off. Masked everything in the general are very very well. I then just sprayed 3 coats of high heat paint on. It looks flawless. I have pics too if you want to see.
High temp paint
[snapback]69206[/snapback]​
rjaz gtp
Naperville
For plastic parts: High Temp Spray Paint
For all metal parts: I would have them all powdercoated, that is the best solution!
F
fastcash
High temp paint
simple green, and a little sodium hydroxide... ;)
98 TGP TOY
Morton, IL
So is it not worth sanding down metal parts? Putting on anything before the painting? I just want to make sure it will last.
Also, any recommendations about what hi-temp color would go with a red gtp?
dole21
South Carolina
i also recommend hi temp paint
I primered all my stuff with a couple coats of gray primer,
then painted the parts with 2-3 coats of high temp paint I got at walmart in the auto section...was ceramic stuff...
6 months later the valvce covers, FWI, strut bars and other stuff still look like new
dole21
South Carolina
no i didn't sand them...just primered the heck out of them...lol
and clean them well before you primer them...used a degreser i had here and scrubbed them as they were very grimy
I
imported_Ron Vogel
Definately scuff it up before you paint. Gives something for the fresh paint to grab. If it's not, it chances a greater risk of flaking off. I'd also use a dedicated paint prep cleaner, or paint thinner to clean before your first coat.
