đź’¦ Detailing Paint Restoration on 95 Supra
Michal_biziak
Oct 31, 2020
6
56
So I purchased this 1995 Toyota Supra that’s been abandoned for years and has been sitting in the driveway being neglected. The first thing the car needed was a proper paint correction.
The first step was to wash the dirt off of the 12+ years of debris that has fallen on the car
Next I clay barred the entire car using Mother’s Clay Bar to take off any surface contaminants that weren’t taken off during the wash. I also had a pin stripe that went across the whole car that looked really bad. I used a 3M Eraser Wheel to take it off.
This should also give you an idea of how bad this paint was. After the pin stripe removal I tried different methods and steps to find out which course of action I needed to take to restore the paint. I recommend starting from the least abrasive procedure to the most aggressive until you find what works for you.
These are the steps that I took for my car
1.) 1500 grit wet sand by hand
2.) 3000 grit wet sand by hand
3.) Meguiars M105 with MicroFiber pad on DA
4.) Meguiars M205 with foam pad on DA
STEP 1 and 2
Wet sanding the paint will leave a flat finish. Don’t worry this will buff out !!
Step 3 and 4
Here are some other pictures of the car to give you a before and after and show what a proper paint correction can do for your car.
Wet sanded
Now mind you, the paint IS NOT PERFECT. This car will get a professional paint job in the near future. But if your looking to improve the look of your paint, Wet sanding is a great method for getting rid of light scratches and fades. I do not recommend wet sanding unless you paint looked like mine or worse!!!
I also restored the front of my headlights.
Here are the steps I took to get this done.
1.) 400 Dry Sand
2.) 600 Wet sand
3.) 800 Wet Sand
4.) M105 compound with microfiber pad
5.) M205 polish with foam pad
119,038
So how does somebody just leave this on their driveway? Something wrong mechanically with it? How is the interior of it?
You always see random pics of Supras (usually NA but sometimes TT) just sitting in a driveway half covered.......or in a background surround by garbage. Its weird how some of these cars live.
Intel
5,889
3,357
Palatine
I mean I am used to seeing that with the younger generation of 300zx owners.. just figured since there were so few of these that would happen less often. I need to find an FD RX7 like that.
Michal_biziak
Oct 31, 2020
6
56
The lady’s husband passed away and she had no interest in driving the car as it is a stick car. The interior is actually in really good condition. Gonna be doing a write up on the interior as well.
Reactions: m_dogg and Intel
Michal_biziak
Oct 31, 2020
6
56
