How do you TroubleShoot the code P0102. It was scan by AutoZone.
The PCM has Determined that the Mass Air Flow input is Lower than expected for the current engine operating Conditions.
well.. if you had a scanner i woulud check your MAFF reading..... because i had that same code and it meant i needed a new sensor... then everything was fine.
