Out of Curiosity
Dasfinc
Mrrrrstang.
Wheaton, IL
How hard is it to LSX swap a 2wd, 2door Jimmy Sport? (Or the Jimmy/S10 platform in general)
I'm sure there are lots of write-ups on these sort of setups, @smokinghot
[MENTION=169]LSx S10[/MENTION] and [MENTION=70]Smokinhot[/MENTION]
Like I said, just innocent curiosity, I'm such a ford guy that I've never looked into it.
And no, I didn't even bother googling it, because I'm sure someone has to have a link saved to a solid write-up instead of shuffling through the interwebz.
SirMarco
of Pingree Grove
Pingree Grove
I had a buddy in Rockford do this to a S10 in his garage. He didn't have much trouble from what I remember.
ktraver97ss
I say what everyone thinks
Roselle, IL
Yeah its been done plenty of times and I think there are kits available for the swap iirc. But , yeah, a quick google would have told ya that.
Dasfinc
Mrrrrstang.
Wheaton, IL
Poked around LS1Tech, and see swap write-ups for everything except S-15 trucks.
I see LT1 kits on Jegs/Summit that will work for up to 2004 S15 trucks, but not an LS kit (IIRC, the mounts are the same, but the headers would be different).
Dasfinc
Mrrrrstang.
Wheaton, IL
S10V8.com Parts Store :: Kits for S10 V8 Conversion :: LS S10 Two Wheel Drive Kit
S10V8.com seems to be the big resource.
And just spit-balling, I wanted to 5.0 swap my explorer sport something fierce, but they don't respond well to being lowered, and only one company makes headers for them (at nearly $1000 a set)....
Seen lots of 350 swaps and LS swaps in S10/S15 pickups, not so often in the 2 door Jimmies/blazers, seems rather easy/straight forward.
No matter what I do next, I want it to be clean, something to take pride in, and something that can do 100% street duty, be practical, and still have fun with.... I just have to accept that I can't have a dedicated track car at this point in my life, which was my mistake with the Bimmer.
Harbor Master
on hot rod tv or one of those shows they put an lsx in a 4wd 4 door s10 blazer once... retained 4wd too. it was actually a decent episode. because of it being 4wd it needed a bunch of work to the crossmember/oil pan to work out...
Dasfinc
Mrrrrstang.
Wheaton, IL
in order to have a nice clean/fun DD... need to finish it my friend
Even if I keep the Bimmer, I plan on tearing everything out, and moving it to a new shell so I can maintain motivation, etc... Like I said, I made a mistake by accepting such a beat up shell to begin with thinking I'd just use it as a track machine.... Street Cars >>>>> Track cars.
Smokinhot
3-man rules!!!!
Lansing, IL
Honestly asking Tony is your best option. Everything was bolt and go for me lol
LSx S10
Lombard, IL
The S10 V8 Swap/Conversion Community poly mounts worked really well for me. If you use an H3 alpha oil pan with a 2wd, the engine will drop right in with no modification. I decided to save some money and just run the truck style oil pan. Had to notch the cross member, but that really wasn't too bad. I was able to use the stock transmission crossmember, just had to elongate the mount holes a bit. As far as a wiring harness, there are several companies that make them, but it's pretty easy to modify a truck or car harness yourself, just very time consuming.
Heres some links with a shitload of info:
******PARTS LIST AND SWAP INFO FROM BLACK X****** LSX Swap. - S-10 Forum
LSx Conversion Information - S-10 Forum
