ok...getting my shit together slowly
Mfdiablo91
Mfdiablo91
Elmwood Park
so im trying to figure out where to get everything from.......
Felpro head gaskets (2)
Felpro head bolts (set)
GM aluminum lower intake gasket set
Gen3 supercharger gasket
L67 throttlebody gasket
L67 valve cover gaskets
Coolant O Rings
Fuel Injector O Rings
Crank bolt
Comp reusable rocker bolts
Upper and Lower coolant elbows (aluminum)
ZZP is selling a kit with all of this for 184.99 which isnt bad
The Full L67 Top swap needed list:
Our ZZP 1.0 Top Swap PCM
L67 Balancer
L67 idler pulley standoff
Supercharger belt
L67 throttlebody
Gen3 blower w/pulley
Gen3 lower intake
L67 heads w/ valve covers
Fuel rails
Injectors (01+ will also need injector connectors)
.....am i missing anything from this list?
i know my options are ebay, craigslist, amazon, junkyard, etc.
Im just not sure which parts are more worth getting where like condition and pricing....
Some guy on craigslist has been holding tog headers for me and theres a lot of blowers for like 100 bucks
Also getting a cold air intake KN, colder tstat 160 degrees , colder spark plugs 103 autolite xp iridium,and tog downpipe then straightpiping with either magnaflow or flowmaster mufflers and after that for awhile il stay where i am
Thank You
1quick
coal city
victor reinz head gaskets rather than felpro, make your own air intake and save the money just buy a k&n cone and a piece of 3.5-4" pcv and use the stock air intake hose with the filter on the end of it, 180 t-stat, copper 104's at 50-55 thousands, and either buy the stuff in one shot from somebody selling it on one of the forums or on craigslist or hit the junk if you cant find any people selling all the stuff in one shot buying it one piece at a time would be a pain in the ass
1quick
coal city
figure out a solid price on the whole deal and what you want as future mods and if its anywhere close to what a base z3 turbo kit cost skip the top swap and save for the turbo kit you will be way happier with the outcome
1quick
coal city
You have almost 300 in just a PCM and gaskets I think your under shooting what it's going to cost to do it right
10sec
Yeah, it's simple but it'll nickel and dime you to death. It won't be cheap, and If you're trying to do it with cheap in mind it won't be very reliable.
02BlueGT
No Fucks Have Been Given
Now apearing in Hanover Park
True, like the oil to flush any spilled coolant out, then the first oil change for 100 miles, plus coolant will be $100+ on its own.
Also, the exhaust setup you are looking at will be extremely loud. 3800's are very loud and drony without a resonator, I'd suggest the one like mine which is a truck resonator from Magnaflow @%1; will know what part # it is.
Otherwise, your parts list looks good. I'd estimate that you will spend $1000 - $1300 all said and done if your doing top swap and exhaust. You could probably do the top swap on it's own for ~$650 if you shop used on the forums for everything other than gaskets.
Mfdiablo91
Mfdiablo91
Elmwood Park
I plan on doing everything at a buddys shop so that will save me labor costs....i hope to find half of the more expensive stuff in a junkyard and just buying all the smaller stuff new.....all this will be done in november when i can start saving money...so i just wanna make sure what im buying from where
