Oil pan leaking
s4rge
Laser Red Stanger
The car has been loosing oil greatly now and its not burning oil its leaking all over my Tranny and ground slowly.
Anyone know how easy of a fix this is? And willing to tackle it if its easy.
$$$ of course.
Zack
4 Doors 4 Life
NW Indiana
I dont think anyone can help until you tell us where it is leaking from.
s4rge
s4rge
Laser Red Stanger
From the oil pan area :confused: :dunno: I see oil by the middle bolt closest to the tranny. My guess is the gasket is bad but im not car smart at all.
Zack
4 Doors 4 Life
NW Indiana
It could be leaking from the Main seal in the front, the oil filter housing, an allen plug in the heads, the cam cover gasket, the oil pan, trans front seal, rear main cover.
I could continue, but im trying to convey your problem cant be solved over the internet.
s4rge
s4rge
Laser Red Stanger
:eek: You just blew my mind with all of that :( . My guess its the oil pan because i see the oil by that mainly and its all over the front half of my tranny.
01bluesnake
Cobra Brigade Mad Scientist
best bet is to clean all the oil off with cans of brake clean very well, add in some dye and drive the car, check every couple days, but you will need a special light bulb to show the dye.
tinosc281
oil pan
could also be your rear main seal.to replace the gasket you either drop the k-member down or lift the engine high enough to slide pan out.major pita.clean all the oil off with the degreaser.use dye just like the other guy recommended.the rear seal you have to drop the trans,
Dana
Bluesmobile
What Tino said, but a leak at the rear of the pil pan is not uncommon on these motors for some reason. Chances are that is where is it leaking from.
The easiest way is to drop the k-member as low as it needs to go without taking it completely off the car, and then drop the pan off the motor.
stock-t-bird
HVAC/R PARTS EQUIPMENT
Thornton Quarry
I have a UV light if needed if your going that route...also have dye,but mine is used in HVAC industry.....
