How low is the oil pressure?
I've got an oil pressure and temp gauge on my turbo prix, L67. The temps hover at 200-202 consistently. Running with a 180* t stat. But also no condenser up front so engine stays extra cool. I have never heard or read of anyone putting an oil cooler on a 3800.
First off, LS7 lifters are drop in replacements and are better than the originals.
Secondly it's only an issue when the oil pressure is low. If it were an issue with the lifters it would be a consistent issue I'm sure
I love how 3800 people shit all over new or different ideas all the time.
They also require different preload. I could see lifters becoming noisy with low oil pressure and on the minimum preload threshhold.
I'd just prefer not to overcomplicate a system and create additional failure points when there isnt a problem to correct in the first place.
Exactly. Low oil pressure -> ticking lifters. Every hydraulic lifter is going to do this.
There is nothing specific to the LS7 lifters here. I'm sure if there is anything to different specs it's going be an improvement rather than a detriment.
GM added these to a lot of earlier 3800 cars to begin with and those didn't have a turbo in their oil system. I'm sure if they saw a reason to spend money on adding them there was a reason for it.
This isn't really that crazy of a mod. It isn't all that different from adding something like a trans cooler which btw sees much higher pressures than an engine oil cooler.
I never would have thought I'd hear someone call an oil cooler overcomplicated.
I couldn’t find your other thread on the car...ran across this on CL and thought of your car
https://chicago.craigslist.org/sox/pts/d/new-lenox-currie-12-bolt-body-stronger/6821157507.html
Another thing lightly touched here is the "oil cooled turbo" talk....when it comes to a turbo, there is really not much cooling going on. Or needed. Only heat to worry about off a turbo would be radiant.
My friend, not only is that a myth, but it's not to let the oil cool off the turbo, it's literally to let the turbo cool off. Manifolds/turbo exhaust housings get VERY hot during track time or "spirited driving", there's a lot of heat that goes into making power. The oil does nothing to help cool it off, it merely just lubricates it, which if you're being picky, is technically a way to keep the bearing/bearings from getting too hot. No car came from the factory with a turbo timer, there's a reason for that. An NA car could just as easily have cracked exhaust manifolds from heat.
I can understand that being one of the reasons for a timer, but lots of newer cars use water-cooled turbos not oil cooled turbos.
Are we really arguing that the oil going into the turbo isn't being used to cool it??
