Okay. I had to try out the Wago connectors and love them. Wire nuts are for the garbage now.
Lemme come over and charge my phone.just threw the switches and breakers, making a whopping 173W!!! I’ve got one inverter that’s not connecting in an easy spot to get to thank god. May just be distance from the wireless gateway or something’s up. Easy things first
I'm sorry, I'll just use it to power up my single LED flash light instead.Quit hogging all the power
So, what you're saying is, solar is the way of the future and we need to eliminate dino fuels.System hasn’t generated shit yet. The monitoring kind of sucks ass too, I’m going to toss on something aftermarket down the road for a better idea of what I’m making. Just tossing an amp clamp on it, system is making almost 2x what the app says
Found I have a bad inverter as well. Luckily it’s behind the easiest spot to get to.
Panels output voltage, voltage at the AC trunk, can’t communicate with it and no status/diagnostic LED.
No batteries. System won’t run unless it’s seeing voltage from the grid. Got as high as 500ish Watts yesterday lol.173w? My tiny setup is capable of 2400w output and carries load of 1500w no problem, esp when the sun is out. Have you been running this thing prior disconnected from the grid but still producing?
Also, did you go with batteries in your setup?
Can charge your phone a bit today...FOR FREE!!!!!!HELL YEAH BROTHER
Have had zero time to look at anything except the bad inverter. Prob won’t resolve anything until spring at this point.
