My anxiety went through the roof look at that picture he posted.I don’t know why anyone has interest in half assing shit at their own house.
Good job on adding the lighting to the attic space, huge difference.
Eyeballing it yesterday, I think I just might be able to get a 14’ 2x6 into the attic without any surgery to the walls/ceiling.
If I can’t, I need to make an opening into my walk in closet wall and that should make it a breeze.
I’ve got a balcony off of my master suite, the sliding door is in just the right spot that a board would angle into the walk in through the master bath then into the closet where the pull down stairs are.this almost seems like one of those situations where you should just make that opening.
Starting on some of the fun work!
I marked all the rafters out on the shingles with a lumber crayon, found the center of the roof then marked out the corners of where my panels will land.
I started with the two mounting feet that land closest to the edge of the array. Measuring up from the roof edge 15.5” I peeled back the shingles, dry fit the flashing to make sure my hole location worked then drilled a pilot hole. 4” long 1/4” diameter spade bit. Squirt some roofing sealant in the hole, a good bead around the underside of the flashing, send the lag bolt home and bobs your uncle.
I only had about 2 hours of time to work managed to knock three of them out. A good chunk of time was layout and being careful to not damage shingles. The rest should go quick. I expect to at least have all the rails mounted on the garage roof by the end of the weekend. Thinking I can get panels, inverters and wiring done completely though.
have you talked with your home owners insurance company on the roof panels? Have heard of companies dropping clients for having solar and aged roofs.
I would Still Make that call to double check, as your insurance will need to know for replacement values.Yes. Premium is a little more, about it. Roof went on the house almost exactly a year ago
It is most definitely a Florida thing. FPL is in bed with the insurance companies (whatever ones are left).maybe it is more of a florida thing since florida homeowners company's are bailing hard.
Garage is done. Tucking all the wires is the worst part of all this so far. It would be much easier with a second person. Same thing for mounting the first row of panels at the eve. Line it up while it’s trying to slide On the rails and pull you off the roof.
18ish hours of work into the garage. Expecting another 60 or so to finish the whole project.
