Offset and width?
Kyle
Downers Grove
How wide can our front tires go wtihout rubbing?
and what exactly is offset on rims a measurement of?
F
fastcash
[snapback]68774[/snapback]​
hunter dog knows this...search his posts and you will be uplifted...
here you go
http://www.ilgpc.com/forum2/index.php?act=...sult_type=posts
Offset is the difference between the centerline of the rim and the actual hub mounting surface. The higher the offset (+) the further in the rim will sit but its also closer to rubbing control arms and frames too.
Read about it here
http://www.tirerack.com/wheels/tech/offset.htm
