TV Official Street Outlaws No Prep Kings Thread
GLADIATOR
aka STROKE-KING
34,137
32,766
New Lenox IL
They just finished filming Mega Cash days in Cali. Boost12 was there racing also. Anyhow, they are sworn to secrecy by contract and can’t say who won. Since I follow most of the street outlaws on FB, I found this picture in a thread from Chuck Death Trap. I think it’s the final race between Ryan and JJ for $100k. Just a guess but we’ll see if I am right.
GLADIATOR
aka STROKE-KING
34,137
32,766
New Lenox IL
The show name has been fubar for a couple of years. I record the show so I cns fast forward through commercials and such. But since the name changes it doesn't always record.
Today it's called Street Outlaws Great Eight "hurts so good". From 7pm to 11pm. After the first hour being the same as last week, it flipped to the correct race in Minnesota.
But lizzy was out early, so not sure about the drama Gladiator was talking about. Or the stuff you posted about is really correct either. So I'm all confused haha
Drama show is tonight. Lizzy and Kye sopa opera...cant wait!!
Bob Kazamakis
I’m the f-ing lizard king
85,419
45,424
JK
Pat has done this a few times now. Not sure why Kye is shocked by this. Pat Musi has a reputation going back to the 90's when he was racing.
I'd die to see Kye show up next year with engines from some other shop. lol
Man if there was ever going to be a push to do that :rofl:
Proline do mountain nitrous engines?
GLADIATOR
aka STROKE-KING
34,137
32,766
New Lenox IL
I saw some FB live vids from PRI last week and they were joking that Kye was going to switch to procharger. It might be true.
Bob Kazamakis
85,419
45,424
JK
There are shops out there that make big hp n/a motors. Not sure of the rules, but Sonny's has semi-hemi engines that are 1,000" and 2,100+ hp n/a.
Rules just apply to weight depending on engine size so that would require a 2500lb min weight which is nothing.
Pro charger cars have a min of 2650 up to 2850lbs depending on size.
  • Wow
Reactions: Jimy Bilmo
Bob Kazamakis
85,419
45,424
JK
I’m sure they’ll change for 2023 but here’s 2022
Engine Power Adder Base Weight
Small Block Naturally Aspirated Unlimited
Big Block Naturally Aspirated Unlimited
Big Block Nitrous (4.840” bore space or smaller) 2350
Big Block Nitrous (4.841” to 5.00” bore space) 2400
Big Block Nitrous (5.01” bore space or greater) 2500
6cyl Prod. Engine* Single Turbo 2400
Small Block Single Turbo 2450
Small Block Twin Turbo – Up to 88mm 2500
Small Block Twin Turbo – Larger than 88mm 2600
Small Block Centrifugal 2500
Big Block Centrifugal up to 121mm 2650
Big Block Centrifugal 122 to 136mm 2750
Big Block Centrifugal 137 to 145mm 2850
Big Block Twin Turbo – Up to 88mm 2850
Big Block Twin Turbo – Larger than 88mm (98mm max) 2950
Big Block Single Turbo 145mm max 2650
Small Block Roots Blower 2500
Big Block Roots Blower 2600
Small Block Screw 2700
Big Block Screw 98% max overdrive 2800
And weight changes depending on other stuff:
General Weight Additions / Deductions:
i. Vehicles running a taller than 34.5 inch sidewall designation tire must add 50lbs.
ii. All big block entries 585 cubic inches and smaller (Non 481X or non-Hemispherical head on any Big Block) with an OEM bore space (4.84 Chevy, 4.900 Ford, and 4.800 Chrysler or smaller bore space) may deduct 100 lbs. from their original base weight.
iii. Big Block combinations with cast block and cast heads may deduct 100 lbs. from their original base weight.
iv. Any supercharged or turbocharged combination with Lock Up convertor or transmission or a lock-up style bell housing must add 50 lbs. Any combination without Lock Up convertor or transmission and running a non-lockup bell housing may deduct 50lbs.
