Official SC HP Thread
musclemerc
Addict
Jan 6, 2010
554
Fordnut: 751HP/617TQ *Highest HP/TQ with -BBS-*
Whipple 3.4L
*5.3L Big Bore Stroker Boss5.0*
Heads:Ported/combustion chambers cleaned up/oversize valves/oversize hardened seats/hardened guides/ceramic coated chambers, valve's head's, and exhaust ports/teflon coated valve stems,cam caps,cam saddles/drilled out oil return holes/Cryo treatments/REM micro-polished followers/Comp beehive springs/Comp Extreme 258 series grind #106260, 222/224 duration, 475int/450ext lift
Bottom end:Cryo treatment & REM polishing on Kellogg forged stroker crank/Pauter cross-beam rifle-drilled billet rods/longer rods with raised wristpins/CP 9.5:1 forged pistons with ceramic & teflon coatings/teflon coated bearing inserts/cryo-REM treated cam gears and chains/billet crank trigger ring/Melling oil pump with billet gears/windage tray/main girdle/ARP rod bolts,cam bolts, main studs & head studs/60 lb injectors/CPR fuel rails/ twin GT fuel pumps
NGK TR6IX plugs
Plasma booster ignition module
K&N conical filter and custom mandrel bent CAI
3.5" upper pulley/6.55" underdrive lower pulley, 16-18 psi boost
NAZ ported Cobra lower intake
110mm JLT MAF
MAFia
LFP oval TB
170* T stat
Evans water pump
EGR delete
FRPP 4:10's
PI 2200 stall
BTS 4R100
Kook's LT's
Bassani 2.5" X pipe
Magnaflow high flow cat's
Edelbrock RPM muffler's
Custom dyno tune
Fordnut: 660HP/555TQ
ProCharger D1SC
*5.3L Big Bore Stroker Sleeved Teksid*
Bottom end:
Cryo treatment & REM polishing on Kellogg forged stroker crank/Pauter cross-beam rifle-drilled billet rods/longer rods with raised wristpins/CP 9.5:1 forged pistons with ceramic & teflon coatings/teflon coated bearing inserts/cryo-REM treated cam gears and chains/billet crank trigger ring/Melling oil pump with billet gears/windage tray/main girdle/ARP rod bolts,cam bolts, main studs & head studs/60 lb injectors/CPR fuel rails/ twin Cobra fuel pumps
NGK TR6IX plugs
K&N conical filter and custom heat shield
3.90" blower pulley/Innovators West 10% OD crank pulley 8 rib
Air-Air intercooler
SCT BA2800 MAF
MAFia
BBK 62mm TB
Electric WP
180* T stat
PHP 3/8" intake spacer
Ported & Polished U/L intake's *TB matched*
EGR flow restrictor
FRPP 4:10's
PI 2400 stall
Lentech transmission
Kook's LT's
Bassani 2.5" X pipe
Custom dyno tune
Marader TJA: 641HP/519TQ *Highest HP with Stock Displacement*
Built 4.6 from Boss 300 Racing
CP pistons 9.3:1cr
Manley Rods
Cobra crank
Ferrera SS valves
Comp cams valve springs
Comp cams custom grind cams & billet steel cam sprocket's
Procharger D1SC 18lbs boost
3 core Air to Air intercooler
Twin Bosch fuel pumps
Custom fuel rails
18 Fuel lines
90mm Lightning MAF
Diablosport Mafia MAFextender
8 rib pully upgrade
SW LT's
2.5" X pipe
Flowmaster Delta 50 mufflers
3500 stall
BC automotive transmission
Detroit Truetrack posi
Moser 31 spline axles
jflave: 636HP/532TQ
Paxton Novi 2200SL w/2.8 pulley 19lbs boost
Foxlake 4.6 long block build motor
CNC ported heads
GT super car cams
Forged lower w/9.3-1 cr
Kook's LT's
80lb injector's
Return fuel system -8 feed -6 return
Aeromotive A-1000 fuel pump
Custom dyno tune by Dennis Reinhart
MM_BKK: 626HP/ 557TQ *Highest TQ with Stock Displacement*
Cobra Longblock conversion
Whipple 3.4L with 4" upper pulley and stock lower
Accufab Single Blade Throttlebody
SCT BA3000 MAF
Aeromotive Mechanical Fuel Pressure Regulator for return fuel system
CPR Fuel Rails
60 lbs Siemens Deka Injectors
Dual GT Pumps with dual -6an feed line to external Y-block
-8an Fuel Line from Y-block to rails
Accel DIS-8 Spark Box with built in 3 steps rev-limiter
Accel COPS with Denso plugs
Stainless Works Longtube Headers
Dynomax Reverse Flow big body mufflers with 4 resonators
FRPP 4:10's
Stock stall speed Boss Hogs torque converter
Custom dyno tune by Performance Evolution
-Matt-: 477HP/400TQ *Highest HP with Stock MM motor*
Vortech V2 S-trim
Water to Air system
8-10psi
Cobra #39lb injectors
40 amp bap
GT supercar pump
SCT BA 3000 MAF
Kooks LT
Deleted cat's
magna flows
J-mod
Cobra diff with c/f clutches
31 spline axles
FRPP 4:10s
Custom dyno tune w/ Zack's trans tune
Fordnut: 476HP/410TQ
D1SC SC
*Stock Long Block*
Denso IT20 plugs
3.90" blower pulley/Romak underdrive crank pulley 8 rib
Air-Air intercooler
SCT BA2800 MAF
MAFia
BBK 62mm TB
Electric WP
180* T stat
EGR flow restrictor
FRPP 4:10's
PI 2800 stall
Reinhart/Art Carr transmission kit
Kook's LT's
Bassani 2.5" X pipe
Custom dyno tune
Spectragod: 472HP/428TQ
Trilogy twin screw 9lbs
SW LT headers
SW high flow cats
JLT cold air kit
Pro-M 80mm MAF
Flowmasters
boost a pump
Custom dynotune
Blackbeauty2: 472HP/402TQ
Vortech V-2 S-trim
Air to Air
3.6 pulley at 8-9psi
PHP intake spacer
Kooks full system
no cats
18" magnaflows
2 1/2" pipe all the way back
MSD COP's
BC automotive stage 2 trans
3500 tripple disc stall by circle D
FRPP 4:10's
Justbob: 445HP/431TQ
Trilogy SC
11.5 PSI
3.2 pulley
lightning MAF
Mafia extender
12" x 4" conical air filter
Walbro 342 fuel pump
BAP
Flowmaster delta 40's
Jmod
Custom dyno tune from Kurgan
Impalaslayer: 435HP/432TQ *Highest TQ with Stock MM engine*
Eaton Swap 3.1 upper +2 lower pulley
GMS COP connectors
Stewart EMP water pump
Kooks LTs (Maucat)
Aero muffler's
3500 Stall
FRPP 4:10's
Custom dyno tune
SC Cheesehead: 430HP/420TQ
M112 Eaton
Stock upper/2 lb lower, 10.7 lbs boost
39 lb Cobra injectors
GT Fuel pump and KB 20A BAP
C&L aluminum intake tube/K&N filter
FRPP shorty headers
Mac Pro-Chamber mid-pipe
Magnaflow hi flow cats
Frozenboost Type 100 intercooler heat exchanger
Custom dyno tune from Mo's Speed Shop
NTD: 430HP/362TQ
Paxton Novi 1500SL
Water to Air system
10psi
FRPP #60lb injectors
KB 40amp bap
GT supercar pump
SCT BA5000 MAF(blow-thru)
deleted 2nd cat's
Magnaflow mufflers
J-mod
FRPP 4:10s
Custom dyno tune by Livernois Motorsports
Did not see any list of equipment or numbers there of from either a 2.3 , or 2.9 Whipple
4.6 engine. I know there has been talk of this set up .....
Is there any specs on a TVR on any engine in either 4.6L or 5.3L . I like the TVR, but I
understand there are issues.
I would like also to see if there is any information on the KB any size on a 4.6L or 5.3L
the grapevine has it that there is something special in the works for this sort of setup.
I hope I am not just blowing smoke up someone ass by asking these questions.
So If you can, Please feel free to advise or tell me I don't know WTF I am talking about.
Thank you for an interesting read anyway.
musclemerc
Addict
Jan 6, 2010
554
IIRC Bodyman has a 2.9 Whipple, I'm waitin his mod list IIRC he has a Whipple also but I think his is corn fed
guspech750
Guspech Superdriller
9,322
6,111
North Aurora
^^ Because its an unfair advantage if you have 2 MMs with the exact same mods. The one with the knock sensors turned off will make more power.
And the problem with that is................????
It's not unfair. Each car listed is different already.
Why not just list both but make a note knock sensor on or knock sensor off. Seems easy and it let's people see the possible power difference between two cars with identical mods but with or without the knock sensor.
I'd like to see the difference and I'm sure others would.
I'd PM you my dyno sheet but I don't have the slightest clue to where both my NA and SC sheets are.
So I'm out.
Looking forward to seeing some numbers from people.
musclemerc
Addict
Jan 6, 2010
554
As soon as I get info on a MM with this combo I will post it in the thread.
E-mail with dyno sheet sent.
I got the email Rex I need your mods list
Can't the frequency be tuned out?
I've done it several times on GM stuff with KB's and Magnachargers.
If it will make you happy the knock sensor is no longer required :bigthumb:
Anything goes! Send me your info in a PM or to my email. Please attatch your dyno sheet [email protected]
:fy:
Jon01
4,102
15,952
I'm good either way, I see what you're saying and it does make sense.
I've always just altered the sensitivity of them in tunes to get around the harmonics roots blowers produce.
My car will have them tuned out as it's an iron block with no boss for them but will not be a contender for high hp, I don't feel like putting a built trans in it anytime soon so 450-500 will be my goal. Plus our local dyno is a real heartbreaker.
Bodyman
203
Warrenton,MO
Correction Travis.. 2.3 on pump gas with a low comp Alluminator 545hp/556tq. Let me know if ya wanna see dyno sheet. This will undoudetly be going up when I swap to SB plenum & TB. To bad I sold my 03 300a I was 500hp on stock motor S-trim Vortech A2A
