Odd hard-to-start problem on 2002 GT
nytebyte
Not Politically Correct
Mar 2, 2004
13,689
21,184
Occasionally, I will have a hard-to-start problem on my 2002 Mustang GT.
The issue will only occur when the engine is warm, but not every time.
The issue usually occurs if the engine is up to full operating temp, then shut down for a short while, then when you try to start it up again, it just cranks and won't start on the first try. Always starts on the second try though. Car starts just fine when cold.
Here's a real world example:
Engine is at operating temp, pull into the dry cleaners parking lot and shut off the car. Go into the cleaners for about 8 minutes. Come back out and try to start the car, but it just cranks. Turn key to "off" and try again, then it starts right up.
What could it be?
Jan 31, 2007
155
My friends stang did something like that for a short time before the fuel pump died completely. I also think the car benefited from a new fuel filter too.
If it's cranking then I am assuming without hearing it myself, that it is getting power from the battery and not enough fuel to turn over.
Zack
4 Doors 4 Life
Mar 21, 2004
6,297
20
NW Indiana
LOL if there is enough power to turn the starter, the fuel pump will have plenty of juice.
nytebyte
Mar 2, 2004
13,689
21,184
Car is not supercharged and 100% stock. Battery is good and starter spins at a good speed.
I was also thinking along the lines of a possible fuel delivery issue.
It does start fine when cold and if I only wait 2 minutes when warm it starts fine. It also starts fine on the second try when it fails to do so on the first.
im going to say the IAC valve... its probably dirty and not allowing enough air during hot starts.. you can test this out by trying to give it 1/4 throttle while its cranking.. if it fires, the iac probably needs to be cleaned.
Mine does start up when I give it some gas on a hot start! Thanks Bob! What would you recommend to clean it?
nytebyte
Mar 2, 2004
13,689
21,184
Just wanted to FINALLY follow up with this.
I didn't seem to have any problems in colder weather, so I didn't get around to cleaning the IAC until recently. Now that the weather is warm again, the car began to have the hard-to-start-while-warm issue.
It was indeed the IAC valve.
I pulled the IAC and gave it a thorough cleaning. Problem is completely gone so far and the car has been starting fine for three weeks now.
