OBDII Q: DTC Fault Type vs DTC Fault Enabled
TommyGloves
CHICAGO
As the title states...what's the difference between the two settings in the PCM? Which allows the emissions readiness tests to show as "ompleted" even if there is a fault? If someone were to say, have the P0440 Evap code...:ph34r:
I would assume leave the DTC Fault Enabled = 1 and DTC Fault Type = 3 - No Reporting.
TIA
