no spark help me
Chitowngst
My sig is my bitch!
Jan 25, 2008
214
Burbs.
I thought you had a GST? Whicn would mean you have a 4g63, but if we're talking distributors, then you have a 1.8 motor. Which I don't know much about.
When you're trying to turn it over, do you smell fuel? The turbo DSM cars don't prime the fuel pump when you turn the key over, but I think 1.8's do.
You clearly have spark, charging is okay, start using an OHM meter on fuel injectors, check to see if the fuel pump is operating. To me, though, it sounds like the ECU.
Lord Tin Foilhat
60,725
56,889
Privy Chamber
If you pull out a spark plug, reconnect it to its wire, and rest the tip against the valve cover while cranking you can verify if the spark is indeed working. Just to get that absolutely out of the equation.
or stick a screwdriver in the boot and turn it over.....ive done that, u can feel a lil shock in ur hand, its fun
