Nitrous Storing Temperature
Rfstang01
Hey guys i just bought a NOS 10lb bottle and its filled and i was wondering where should i store it in my house or my garage(garage is really hot)
batman
Surrounded by 10 points
leave it in your trunk...
R
Rfstang01
well i only really wanted to have it in my car when i go to the track.
willsmysticcobra
Classifieds Mod
Lake Zurich
I just pulled mine from the trunk cause my car gets real hot... the bottle is sitting on my book case now lmao
rocket5979
Gearhead
Round Lake, IL
Trunk is totally fine if not exposed to direct sunlight. The bottle pressure will go up but nothing you cannot purge a little out to get back down to proper pressure. Those bottle overpressure burst discs are usually rated to 3000psi which is allot more than that bottle should ever see even fully filled on a hot ass day. I leave mine in all the time. Garage or in home storage are both totally fine for storage.
94' cobra 351
What about the winter time? I assume you would drain the bottle for the winter months when it's not in use?
rocket5979
Gearhead
Round Lake, IL
You don't really have to. Nitrous is a cryogenic liquid so it is not like that bottle valve and seals is not used to handling temperatures much much colder than what winter ambient temps can get down to.
94' cobra 351
I wasn't worried about the temperatures, I was thinking the pressure would wear on the seals/valves. Just figured it'd be better to drain it if it's just going to sit for over six months.
rocket5979
Gearhead
Round Lake, IL
If it were me and I had a significant amount left in the bottle I would just store it as is. If I was pretty low already then I would just empty the rest out and let it sit that way if I am not using it for 6 months at a time. You can usually plan when you will have your bottle empty anyways through just finishing the season out with a few fun runs. :biggthump
