Be the OG and run it, good price ??Can’t decide if they’ll look out of place/weird. Literally cannot find pics of them on a genesis, just genesis wheels on stingers.
I need to introduce you to wobble plusLeft work early and knocked out spark plugs and some Buick stuff. People aren’t wrong, passenger side is not easy but people saying it took 3 hours might have brain damage….
Just took 2 swivels together
Oof that’s not cheap, probably would still need a swivel though as that was a tight fit. Had to pull the boot off the coil to get them out. Also there’s nearly zero slack in the plugs wiring.I need to introduce you to wobble plus
Snap-on Store
shop.snapon.com
Get 3/8 and 1/4 sets and thank me later
I have only run a JB4 on my old X5. I never sent logs, but from all the forum shit I was reading, they're super receptive, so send one over!
Thought you had one on the new carI have only run a JB4 on my old X5. I never sent logs, but from all the forum shit I was reading, they're super receptive, so send one over!
Nope, APRThought you had one on the new car
I’ll probably spring for this at some point. I know my car is probably fine but I feel a little unique being at 6k feet of elevation.I know people who send logs. They usually get replies back pretty quickly. They are very active on a few forums as well. They seem to care about their customer service.
I know they will spice up the 93 tunes a little if you ask. Then when you go to the ethanol blends, they will have you send various logs. Especially if it is a flex-fuel tune. Where they have you log at different E percentages. Everyone I know who has had communications with them has had nothing but great things to say. Be it a BMW, Hyundai, or Audi.
George is super responsive. I sent him logs on my wife's Q7 and he made some minor tweaks to Map 3 over the "stock" Map.
Flex-fuel is great. But I would still send them logs now. If they see any issues or things that need to be tweaked, they seem happy to help.I’ll probably spring for this at some point. I know my car is probably fine but I feel a little unique being at 6k feet of elevation.
Fuel-It! FLEX FUEL KIT for KIA/GENESIS 3.3L
If you're running E85 or ethanol mixes in your Audi, you need this kit! It's plug and play with a Bluetooth ethanol sensor. Easy 15 min install. Fast Shipping.burgertuning.com
Less oxygen = less susceptible to pre ignition plus direct injection. Not sure going to lean is worse here vs sea level.Don't want to go lean at that altitude
I mean it’s not leaner though, afr is afr. It’s adjusting fuel to compensate for oxygen.Higher altitude, leaner already, and if you're going even further lean. Probably doesn't matter as the tunes are likely pretty damn safe, and tons of people never run logs and adjust.
NVM, just saw what I was looking for. They changed some shit a few years ago I guess. There used to be a "high density" tune.I mean it’s not leaner though, afr is afr. It’s adjusting fuel to compensate for oxygen.
