New Project - FDW... four door whore
billzrx7
May 26, 2013
571
4
So.. I got bored with my boat. Had $1800 into it including the cost of it. Traded for this ugly thing:
86k Miles, no rust, underside is clean. Interior is all there but the plastic is degrading. Seats dont have any tears. It drives really nice actually. SBC 400 with a mild cam, hooker headers, edelbrock RPM intake, blah blah blah.. all pushed through a TH350 with a shift kit and an open rear end. HUZZAH for one tire fire!
So if anyone has a 7.5" posi unit laying around or a whole 8.5" 10 bolt / fox body 8.8.. let me know
Not sure if Im just going to throw some aluminum heads on this thing and a 150 shot or if Ill pull it out and go LS swap.
Ron Vogel
5,174
4,273
Ron Vogel
Many Regal g bodies had posi units. I found a couple years back in the u picks off 171/83. You might get lucky. Although I had a built 400 Pontiac that made short work of trashing a 7.5. You could do what I did and swap in a Chrysler 8 3/4”...although it takes a bit of fab work.
Ron Vogel
5,174
4,273
Ron Vogel
manual steering is fine in these cars.
no need for power
I know, mine was manual. Turning from a start takes some effort, but once you’re going it’s ok...well, except how many turns lock to lock. The older PS units didn’t like high revs to much, and I built my 400 Pontiac motor for high revs. Kept having problems so other than the weight savings, that was the other reason I went manual.
You don’t need heat either, I’d chuck the HVAC too. Frees up a ton of space under the hood. Really easy to make a block off plate for those cars.
