New lightnjng throttle body
Jokerzl
Forum Sponsor
Ashkum
We got whipple to make us a 170 mm throttle body for TVS m122 lightning guys.
Flows 2100+ cfm
ZephTheChef
Wichita, KS
Lol yes you should
So what's the money on that bad boy? And if I used the stock TVS elbow, would you throw in a pipe to curve it around the right direction and adapt it to my 4" round intake? Any idea on if a Ford TPS could be wired to work on my 3800 or would I have to figure out something tricky?
Jokerzl
Forum Sponsor
Ashkum
$400-500
How many wires on a Pontiac tps?
Yes I could make you a pipe good sir
ZephTheChef
Wichita, KS
The brief research I did on the matter turned up a bunch of adapter harnesses, so I presume it would work. Most of them are for FAST or other aftermarket computers that utilize a GM sensor, but are being used on a Ford application. So it's a ford sensor with a GM wiring pigtail. Which is theoretically exactly what I would need to do. The voltage vs actual throttle position might vary, but if it's not a huge difference it's easily tuned around.
ZephTheChef
Wichita, KS
So I would need an F-150 lightning throttle position sensor with this, right? Any particular year range? I want to go pick one up and wire it in and just see what it reads like on my car. If that part works, I will probably want to pick one of these up from you, along with an elbow to adapt to my maf/intake.
Jokerzl
Forum Sponsor
Ashkum
97-03 tps sensor
They are 75
Give me an address I'll mail you one
ZephTheChef
Wichita, KS
97-03 tps sensor
They are 75
I will hit up our local salvage yard first and see if I can come up with one and snag a pigtail too. I buy so much crap from them for the car lot that they usually give me the little stuff for free.
