New half shaft clunk
m_dogg
Brookfield
I've replaced drivers side half shaft year ago with A1 Cardone unit which failed after a year minus 5 days. Started to vibrate under accel and made this metallic clunk when going from drive to reverse and vice versa. So I sent it back - lifetime warranty, no more vibration but the clunk is still there. Could it be the new half shaft is garbage or...is my trans starting to act up? It has zero issues as far as shifting/slipping, fluid is nice and red no funky smell or anything.
Jfrost
Fiero's are addicting
Brookfield
If the vibration is gone and clunk still present I'd suspect either trans or engine mounts. How many miles on your car and are those mounts still original or been replaced?
m_dogg
Brookfield
You can really hear it with foot on the brake and going D/R R/D with slight throttle.
Jfrost
Brookfield
I would really suspect engine/trans mounts considering the noise and 100k on it.
m_dogg
Brookfield
Yeah...I just looked at the trans mount, it's all squished, ordered a replacement. Probably a coincidence that it went bad same time as the axle.
Euro
GM or Nothing
Roselle
Yep, that sounds like it to me. I think I actually did both the driver's axle and the lower engine/trans mounts at the same time haha
boostedguy05
not well known
ya, you might as well replace them al while down there.
m_dogg
Brookfield
Replaced trans mount, no change and it's definitely coming from the driver's side. I guess I will find out with time what that is lol
m_dogg
Brookfield
So I got kinda pissed off, took my cheater bar and torqued it down to fuck you ft/lb...no more clunk lol
My torque wrench goes up to 150...soooo maybe I got it up to around 180, had it @ 118 originally. Both bearing and axle are on warranty so we'll see what happens.
m_dogg
Brookfield
Have a feeling my torque wrench is inaccurate. Got another one on Amazon to compare...
ZephTheChef
Wichita, KS
Are you talking about the axle nut? I always impact them on good and tight and never have an issue. Probably twice what you'd get to by hand. Not sure why that would cause a clunk though, I mean it's splined and at 100+ ft-lbs it's not like it isn't tight, even if it's not as tight as it should be. I mean there certainly shouldn't be any slop at that point...
m_dogg
Brookfield
Yep, the axle nut.
