Haven’t posted in here in over a year. Still stock clutch and stock software this year but have done more supporting mods to get it ready for increased power next year. The stock clutch being the Achilles heel of this platform is a real bummer.
Replaced the 21.7mm stock rear sway bar with a 25mm ST suspensions bar.
Not sure about this mod. I had an even stiffer RSB on my MK6 and it felt great. Cruising to epic deli we took a hard right with some elevation and I feel like the rear suspension got unsettled a bit and felt a bit tail happy. Not sure if it’s the stiffer rear sway not playing nice with the lowering springs or if it’s an issue of preload that adjustable sway bar end links would alleviate. Probably going to a set of Bilstein coilovers in the future so I’m leaving it alone for now.
Didn’t do anything to the car until a few Black Friday deals got me this year. Picked up an Integrated Engineering open intake for $75 off. Based on testing I’ve seen recently it doesn’t increase IAT’s over the stock box and it basically lets you hear the turbo and diverter valve. The stock airbox is good up until you go big turbo so you’re really only buying an intake for looks or sound.
Had been eyeing these Black Forest Industries billet/poly mounts since I had my MK6.
The stock mounts are cast steel fluid filled rubber junk. with 11k miles at stock power levels both the engine and transmission mount had a lot of slop in them and you could feel the engine flopping when starting from a stop. VW was nice enough to bury the trans mount under the battery, ECU, and this wiring harness. Car feels much more solid now but the initial NVH is a bit much at low speed low RPM. They’re supposed to be livable at 50 miles and fully settled around 500 miles.
Just for [MENTION=410]Bruce Jibboo[/MENTION] I also swapped out the rubber shifter cable bracket bushings with aluminum. I’m officially out of shifter bushing upgrades to do.
Hopefully next year I’ll replace the clutch, down pipe and intercooler and go with either a stage 2 flash or a Cobb Accessport pro tune and call it a day.
